jenserik
Jens Nielsen
(1 posts)
07/03/2013 03:32PM
Rover 14CUX Electronic Fuel Injection
Posted by: jenserik
Date: July 03, 2013 03:58PM
I wonder what the purpose the "Road speed input" has to the system?
lars49
Larry Barnes
Colorado Springs
(177 posts)
06/11/2009 02:12PM
1980 MGB GM LA1 3400 V6
Re: Rover 14CUX Electronic Fuel Injection
Posted by: lars49
Date: July 03, 2013 09:28PM
Is the dashboard fed the PCM? I know the car from which my GM PCM came, the dash instruments are electronci and are fed by the PCM and BCU. That is not needed in my setup but I found that the PCM also has tach and speedo outputs which are proving to be useful.
Paranoia would indicate something far more sinister :-)
Edited 1 time(s). Last edit at 07/03/2013 09:28PM by lars49.
(1367 posts)
Date: July 04, 2013 09:24PM
The road speed input lets the ECU know whether the vehicle is moving or not.
It can then calculate idle speed and decel fuel cuts etc.
The system will run OK without the input but will run better with it hooked up.
The frequency of the speed input doesn't matter. The ecu just looks for a pulse to determine vehicle movement.
Hope that helps
