Re: Mystery starter ring gear, Rover? Buick? Other?
Graham, Is this externally balanced,(off-set weighted) ? OD = 13.08" but truly 321mm id. ? USA made or ? USA made, I would guess 300 Buick V8 ? Cast not billet ? I suspect small holes near od. are for pin weight, fine balancing,(popular with Buick). "Pioneer" of USA, has a dimensional, starter ring gear chart , very usefull. Good Luck, roverman.
Art,
much appreciated, I will try and locate the Pioneer chart The flywheel pictured is Australian made, a Leyland P76 Engine is a clone of the Rover V8 with some changes; the crankshaft stroke was 88.9mm and the crank, once it has had some machining done to the counterweights, makes for a Stroker motor in a Rover 3.9 Block However its running a Rover starter and the Rover/Buick flywheels have 156 teeth best GW Edited 1 time(s). Last edit at 12/11/2013 12:50AM by RoverP6B. |
