robert1839 Tristan Cook 5579 Timber Ridge Dr, Mt Vernon, Skagit, Washingto (118 posts) Registered: 05/06/2013 11:11PM Main British Car: MGB GT 1972 Buick 215 |
fuel pump
i have realize that my engine has a mechanical fuel pump. dose the engine have to use this pump or would the MGB electric pump work or would u suggest i use the mechanical one?
Re: fuel pump
Shouldn't be a problem switching from mechanical to electric fuel pump - block off plate required for the old mechanical pump hole and a pressure match for the electric pump (which should be mounted close to the fuel tank for best performance)..
A std MG 'SU' diaphragm type fuel pump typically puts out about 2-1/2 psi. |
Re: fuel pump
If you use the message board's search feature, you'll find numerous threads about pump alternatives. There's also a new-old-stock Facet electric pump for sale (cheap!) in our classified ad section.
I can't think of a single car on this website that's using a mechanical fuel pump, but I've often wondered how much more reliable these cars might be if we did. |
Re: fuel pump
what kind of PSI would i need if i got the electric
Re: fuel pump
Quote:You are going to have to tell us what engine you have (and assuming carburetted VS Fuel Injected) |
Re: fuel pump
Edelbrock's 1404 is the most popular carb for Buick 215s on this website, although some people have used Rochesters or Holleys. (Edelbrock carbs are similar to the Carter designs they were adapted from.) Here's a link to the owner's manual for an Edelbrock carb. Fuel pumps and specifically fuel pressure requirements are discussed on page five.
[www.edelbrock.com] |
Re: fuel pump
its the Oldsmobile 215 and i have a carburetor from a ford f250
eyeosteverino Steve Kimball Southwest NM (30 posts) Registered: 03/02/2008 10:58AM Main British Car: 67 Sunbeam, 2.8 L V6 Ford, |
Re: fuel pump
Response is a bit tardy, but I used the stock mechanical pump in my GB along with the stock Rochester 4GC carb, as Buick designed it. I did however, install an electric pump back by the tank to use as a booster to prime the carb and aid starting after a long idle period. The added restriction of this pump does not restrict the flow of gas enough to matter.
