Addicted Mike Hagadorn Warren PA (132 posts) Registered: 09/27/2013 03:46PM Main British Car: 1976 TR7 Victory Edition Ford 302 |
Does this look like a new set of gears?
Re: Does this look like a new set of gears?
Yep, those look new to me.
You'll get a bit of pattern on them from the inspection process. If they'd been run you'd have silver showing. As long as the pattern is even and centered you're good to go. Jim |
Clean the grease off so we can tell. Like Jim says, the teeth won't be black where they mesh. They will be shiney.
Agreed. Looks like a new set.
The grease is a little scetchy though. Is it covering some rust marks? If the teeth clean off nicely you're good to go. Cheers Fred |
Ok Guys,
I cleaned and inspected the gears as you suggested and convinced myself that they had not been installed previously. Now, I am struggling to get them set up. Here is what I have: The 4.10's I took out had a 0.035" pinion shim, which is what I started with even though it seemed big. With about 0.010" backlash, the drive pattern looked nice but the coast pattern was out on the heel (similar to the pics above). Reading and reading and reading, the coast pattern can be brought toward the toe by reducing the pinion shim and/or decreasing backlash. To help myself, I have layed lines and notes on the pictures (based on Ford instructions). If this looks wrong, let me know. I dropped backlash a few thou with the 0.035" shim, and it moved the drive pattern too far toward the toe. So, then I decided to try reducing my pinion shim. I have tried 0.031 and 0.028, but I'm just not getting the patterns where I think I should be (See pics above). My thought right now is to bring the pinion shim back up (maybe try 0.033) and get the drive pattern centered up with backlash. I'm sure the coast pattern won't look right.... Any other experiences or suggestions you can offer would be appreciated! Thanks Mike Edited 2 time(s). Last edit at 08/02/2014 11:59AM by Addicted. |
This is looking a bit better...
and this may be the winner: It seems strange that reducing backlash from 12 to 9 pulled the coast pattern out onto the heel of the tooth. Oh well. Drive side looks good to me in the 9 to 10 thou backlash range. Edited 1 time(s). Last edit at 08/02/2014 02:05PM by Addicted. |
Jim, They are 3.15's, which isn't very common. I was debating between 3.08 and 3.27... Then I was on Late Model Restoration, and saw they had Ford Racing 3.15's.
That is a great video. Thanks. I think I watched it several months ago when I was setting up my 4.10 backlash. I guess I was trying to do what he said by lowering my pinion dept to try to balance heel/toe on the coast and drive sides. He does say that weird stuff happens on some gears. That may be my situation! Edited 1 time(s). Last edit at 08/02/2014 01:30PM by Addicted. |
