peter7907
peter miele
(9 posts)
01/26/2010 05:08PM
timing cover to fit 3.5 rover
Posted by: peter7907
Date: February 03, 2015 10:47PM
Hi, looking for a timing cover to fit 3.5 rover. If you know where i can source one, that would be great
thx
Re: timing cover to fit 3.5 rover
Date: February 04, 2015 03:05AM
This old thread might help: [forum.britishv8.org]
peter7907
peter miele
(9 posts)
01/26/2010 05:08PM
Date: February 04, 2015 10:58AM
Thank you. Do you know if the cover seal is mounted from the front or back? I Understand original Buick timing covers the seal was installed from the back.
Thx
Date: February 05, 2015 10:18AM
Crank seal?
peter7907
peter miele
(9 posts)
01/26/2010 05:08PM
Date: February 05, 2015 10:50AM
Hi - spoke to [www.silver-seal.com]
I was told all new after market Front timing covers are able to have the rubber oil seal mount and accessible from the front.
Thx
Date: February 05, 2015 06:54PM
I don't recall if the seal went in from the front or the back on the stock covers. I'm not sure it really matters. The best thing you can to for the front seal is wither use a new damper or install a stainless sleeve on the damper nose. Those work really well. A neoprene seal will go right in the old cover, and if you do have to replace one it's going to be a lot easier with the cover off the engine anyway even if it can be installed from the front. Aftermarket covers tend to be expensive, and sometimes of questionable quality. If I was going that route I expect I'd spring for the cover from TA-Performance. Pretty high quality stuff from those guys.
peter7907
peter miele
(9 posts)
01/26/2010 05:08PM
Date: February 06, 2015 12:54AM
Hi - thank you for your input
Thx
Peter
Date: February 06, 2015 02:36PM
You are correct, the OEM seal installs from the back.
Date: February 06, 2015 03:05PM
The Buick/Olds 215s came with rope seals. I don't know for sure, but I thought the early rover covers had rope seals too.
I switched to a Buick V6 cover years ago. Still has its original seal. IMHO, neoprene seals should last a very long time and you should be about to remove/reinstall your timing cover without worrying about damaging them.
Date: February 06, 2015 06:45PM
Just pop out the rope seal retainer on the inside and a neoprene seal presses in.
(4513 posts)
Date: February 07, 2015 09:11AM
Yep. That is what I did.
minorv8
Jukka Harkola
(269 posts)
04/08/2009 06:50AM
Morris Minor Rover V8
Posted by: minorv8
Date: February 07, 2015 10:38AM
Yes, 1975 Range Rover engine had rope seals.
Date: February 07, 2015 10:41AM
I think the Buick V6 neoprene seal is a direct fit but not positive. I used the one TA sells for both my 34 and the Roadmaster's 455.
