Engine warning light from 94 GM 3.4 PCM
A very simple question, can anyone see a reason why I can't use a small 12v red led pilot light to signal a fault condition? I am concerned about it having too low a resistance to ground unlike a conventional bulb.
See: [www.ebay.com] Edited 1 time(s). Last edit at 09/01/2015 07:08PM by limey222. |
Re: Engine warning light from 94 GM 3.4 PCM
Should be OK, I used a orange LED for C E L.
I just ordered an Orange 12V. led from Speedway motors assortment and connected directly to the feed from my ECM. Nary a problem, it has illuminated; so it works. No parallel series so is resistor needed?
Right, Dan. I was thinking of a bare bones LED.
Kelly, in series in a basic LED application to limit the current (& adjust the brightness). |
Quote: Carl, I used the LEDs shown in the top pic in my MG. The blue LED high beam indicator was blindingly bright compared to the others, so I had to add a resistor in series to tone it down a bit. |
OR, just purchase from Speedway, solder and shrink wrap & mount. No reason to complicate things :-)
