Rover 3.9L Block, 4.2L Crank, & Buick 300 Heads
There are several ways to do this, most involve a good bit of machining. I have spent quite a few hours comparing recipes with calculators found here.
United Engine & Machine Way back in 2005, I was looking for a better piston for the 3.9. I stumbled across the Chevy 305 piston. Back then, I just wanted a piston & rod that would work with the 3.9. Kevin Jackson & I had some exchanges on the V8 email list. He was looking for pistons, too. He wound up using the 305 pistons with a 5.85" rod on a 4.2L crank. He built it, it runs great. Now, I am trying to keep machining costs down. So I am juggling using the stock 3.7 bore with rods that hopefully won't have to be narrowed & heads & block that won't have to be skimmed. Not working out, so far. :) I moved the relevant posts from the TA Head thread over to this new thread. Some are just shown as quotes. Edited 4 time(s). Last edit at 06/23/2016 11:18AM by MGBV8. |
Re: Assembled TA Rover cylinders (getting ready for the flow bench)
Carl, You will have more quench with the later Rover heads 28cc chamber than the 300 Buick 58cc open chamber. I read something a while back where they recommend a dish about the same size as the chamber, oval shape. Piston at zero deck. I've searched high and low for a piston for the 4.2 crank. you need about 1.45 compression height for a 6" Chevy rod combo. For 6.125" rod the Buick 3300 V6 is close. EDIT: had 350 rod length. The 75-77 oddfire 231 V6 has the same length as the 300 V8 at 5.96. It has the later capscrew design. You would need a compression height piston of 1.485. This .040 over 3.66 3.3 Chrysler piston has the dish I'm talking about and 1.255 compression height.
Edited 6 time(s). Last edit at 06/12/2016 12:30PM by mgb260. |
Thanks Paul. I was trying to figure out Carl's combo with 4.2 crank. Zero deck with .010 decking. 3300 Buick V6 pistons and 6 1/8" Chevy rods. For the price I would use NASCAR take outs and have crank turned to Honda journal size. Or use the Lunati adapter rod bearings to use more common and cheaper 2.1 SBC rods on 2.0 small journal crank size. I think with your stroker combo You would want aftermarket capscrew rods and probably have to clearance the block in a few places.
Edited 2 time(s). Last edit at 06/10/2016 10:28PM by mgb260. |
Re: Rover 3.9L Block, 4.2L Crank, & Buick 300 Heads
Quote: Quote: Edited 1 time(s). Last edit at 06/23/2016 10:55AM by MGBV8. |
Carl, On Chris Gill's 300 stroker(350 crank) build we cut costs on the 300 heads by using slightly larger valves that use the stock seats. 80's 2.8 Chevy V6, 1.72 intake and 1.42 exhaust and Z28 Chevy valve springs. You should either use locktited studs or steel inserts for the rocker arm hold down threads. On my old build I had new seats and 1.74 intake ad 1.50 exhaust Ford 2.3 SOHC valve and Chevy Z28 springs. I tried talking Chris into Alex's Parts beehive springs but the crank machineing cut too much into the budget.
