markoll
Mark Ollerton
Victoria, BC Canada
(7 posts)
08/31/2014 01:43PM
1980 Rover 3500 SD1 3.5 litre
ID my Rover v8 ?
Posted by: markoll
Date: January 13, 2017 02:58AM
hi all
im about to start the 4.6 engine swap in my canadian market 1980 Rover 3500.
we cant find any info on what the # on the motor corresponds to :
the # on the motor is 09D00028A it also has CR9.37:1 stamped above the engine #
anyone have more info ?
tx mark
Victoria, BC Canada
88v8
Ivor Duarte
Gloucestershire UK
(1041 posts)
02/11/2010 04:29AM
Re: ID my Rover v8 ?
Posted by: 88v8
Date: January 13, 2017 05:02AM
9.37 is the compression ratio.
I think, and I am open to correction here, that 09D indicates an engine from a Discovery with sequential injection.
Ivor
(4512 posts)
Date: January 13, 2017 10:40AM
Think so.
[www.getallparts.com]
markoll
Mark Ollerton
Victoria, BC Canada
(7 posts)
08/31/2014 01:43PM
Posted by: markoll
Date: January 13, 2017 11:24AM
ok thanks for that info. i knew cr was compression ratio.
i was told the motor was a 4.6 from a range rover but i am not sure.
ive been trying to verify if it is a 4.6
tx mark
(1365 posts)
Date: January 13, 2017 12:26PM
From what I know the "D" identifies a 94mm cross bolted block.
Which means that you need to figure out the stroke to determine the engine size.
Pretty easy to do really.
Remove a spark plug and insert a thin steel rod or wire to touch the top of the piston.
Turn the engine over by hand and measure the piston stroke directly.
82mm means it's a 4.6
71mm means it's a 3.9/4.0
Live like you mean it.
Date: January 13, 2017 04:46PM
OR, if the pan is off, crank counterweight will say 4.0 or 4.6. The safer way to buy an RV8 is with both heads removed, for a close visual inspection of all 8 bores, ( no water stains/etc), and NO distance between top of liners and decks. Good Luck, Art.
markoll
Mark Ollerton
Victoria, BC Canada
(7 posts)
08/31/2014 01:43PM
Posted by: markoll
Date: January 14, 2017 11:55AM
tx for all the advice guys
we are going to be changing the pan prob next week so i will check the counterweight then.
i went to the local jag land rover dealer and they couldnt find anything with the engine # either
tr8todd
Todd Kishbach
(390 posts)
12/04/2009 07:42AM
Posted by: tr8todd
Date: January 14, 2017 12:48PM
Pretty sure its a 4.6 out of a late Disco 2. Probably a 2003. I have a 4.6 from a late 2003 built in the summer of 03 that starts with a 08D. It has the same 9.37 to 1 CR.
Edited 1 time(s). Last edit at 01/14/2017 12:53PM by tr8todd.
(4512 posts)
Date: January 15, 2017 11:27AM
These links point to the 09D being a Rover 4.6L engine.
ECM for 09D 4.6
[goecm.com]
Quote:
I found a 09D 4.6 short on craigslist and carried everything to it.
[discoweb.org]
markoll
Mark Ollerton
Victoria, BC Canada
(7 posts)
08/31/2014 01:43PM
Posted by: markoll
Date: January 16, 2017 12:07AM
gr8
thanks todd and carl
tr8todd
Todd Kishbach
(390 posts)
12/04/2009 07:42AM
Posted by: tr8todd
Date: January 16, 2017 07:15AM
Over the years my dad had 3 of those SD1s. All of them still had the 3.5 but I installed cams and 4 barrels in them. They were a blast to drive. Interiors fell apart, but they were fun. There's an 04 disco for sale right down the road from me for $1800. Seriously thinking about adding it to the fleet for my 17 year old daughter's first car. P38 Rovers are abundant and cheap around here. My wife's 01 Range Rover HSE only cost me $1000, and a couple of months after she registered it, someone tapped her rear bumper. We got $1400 for the "damage".
