Johan3500
Johan Van Wyk
(9 posts)
03/06/2009 06:17AM
Hydraulic Cam Followers
Posted by: Johan3500
Date: November 27, 2017 03:57AM
Hi!
Are Rover V8 and Chevy 350 cam followers interchangeable?
Any ideas why 3 of the 4 exhaust valve followers on the Left-hand bank of my 3500 are totally destroyed? No abnormal wear on any of the other 13 followers! Those 3 are hollow by about 1/8". The corners have started to chip off! They run on a Crane 218 cam and there is a high volume oil pump in the engine.
Thank yo.u
(2463 posts)
Re: Hydraulic Cam Followers
Date: November 27, 2017 05:59AM
Johan, The Chevy lifters are close but the oil hole is a little higher and can be exposed with a high lift cam. Buick 350 lifters are perfect. I'd look at changing your cam also.
Date: November 30, 2017 10:52AM
Adequate clearance from coil-bind on these problem exhaust ? I suspect if hydraulic lifter excess bleed-off, would have clatter from day one ? Dual springs ? Break in cam with singles ? More work, but you might enjoy a hyd. roller ? Good Luck, art.
