blockmom
Chuck Anderson
(6 posts)
10/02/2017 08:27PM
drop base air cleaner for 4 barrel carter 400 cfm carburetor
Posted by: blockmom
Date: December 31, 2017 02:03PM
Can anyone suggest at web site - with a part # - for a 2'' drop base air cleaner for 4 barrel Carter 400 cfm carburettor with a 51/8'' throat?
Thank you
(2463 posts)
Re: drop base air cleaner for 4 barrel carter 400 cfm carburetor
Date: December 31, 2017 02:57PM
Corvette Holley drop base modified to fit.
v8mgb
Jim Miller
(155 posts)
01/01/2008 11:38AM
78 MGB Buick 215
Posted by: v8mgb
Date: January 01, 2018 06:18PM
MR. GASKET 4339 should work.
Per website description.
Chrome-Plated Low Rider Air Cleaner
14'' Diameter
2-1/4'' Tall Air Cleaner
Fits 5-1/8'' Carb Neck
40indianss
don foote
(83 posts)
08/01/2013 04:35PM
Posted by: 40indianss
Date: January 01, 2018 11:29PM
I used the mr gasket drop base on an edelbrock 500cfm with electric choke on my 4.6 rover with a Buick 215 intake manifold. It was necessary to modify base to clear the choke body. Everything else fits easily and about 3/4" hood clearance when closed
Date: January 02, 2018 11:23AM
They also make offset drop bases. If hood clearance is an issue, those can help by shifting the air cleaner toward the back a bit. That also might let you use a bit less of a drop too..
88v8
Ivor Duarte
Gloucestershire UK
(1041 posts)
02/11/2010 04:29AM
Posted by: 88v8
Date: January 02, 2018 02:54PM
Spectre may have something.
[www.spectreperformance.com]
Cold air, what your engine needs.
Ivor
