limey222
Michael Cubbon
Portland, OR
(129 posts)
08/01/2015 12:55PM
1969 MGB GM 3.4L V6
To owners of 93-95 GM 3.4 conversions
Posted by: limey222
Date: October 30, 2017 05:11PM
Recently my car has developed an annoying stumble if I let the revs drop too low while lugging around town in 2nd and 3rd. Previously I was always amazed by its low end torque and it would pull away in 2nd and 3rd as long as it was moving forward at the time. Now when i go to accelerate there is a stumble like it is going to stall and almost a misfire before it recovers and accelerate normally. All sensors were replaced just over a year ago. New coil pack and base about 6 months ago. New injectors and fuel regulator valve two months ago. No codes are showing up on my laptop.
Any ideas?
Edited 2 time(s). Last edit at 10/30/2017 05:12PM by limey222.
Scott68B
Scott Costanzo
Columbus, Ohio
(562 posts)
10/25/2007 11:30AM
1968 MGB GM 5.3 LS4 V8
Re: To owners of 93-95 GM 3.4 conversions
Posted by: Scott68B
Date: October 30, 2017 07:09PM
Did you go with the stock flowing injectors or the greater flowing injectors you mentioned you wanted to go with?
limey222
Michael Cubbon
Portland, OR
(129 posts)
08/01/2015 12:55PM
1969 MGB GM 3.4L V6
Posted by: limey222
Date: October 30, 2017 09:57PM
OK, Here is what might be considered a strange question. Should the ECM controlling a 94 GM 3.4L engine conversion always be powered up?
The reason I ask this is that I have a hidden, dual pole battery isolation switch installed which disconnects both + and - of my battery.
Got to thinking about this and I need to know if this means that my ECM is having to re-learn every time I drive the car or does it have an internal protected memory for the settings
88v8
Ivor Duarte
Gloucestershire UK
(1041 posts)
02/11/2010 04:29AM
Posted by: 88v8
Date: October 31, 2017 05:17AM
Even if it does, these ancillary batteries are not ever-lasting
Ivor
Scott68B
Scott Costanzo
Columbus, Ohio
(562 posts)
10/25/2007 11:30AM
Posted by: Scott68B
Date: October 31, 2017 05:27AM
It will do a re-learn if you disconnect power from the ECU.
mstemp
Mike Stemp
Calgary, Canada
(223 posts)
11/25/2009 07:18AM
1980 MGB Rover 4.6L
Posted by: mstemp
Date: October 31, 2017 07:59AM
Rather than using the disconnect you could,wire in a battery tender. Try that as a test to see if it solves the running issue. I use that on my rover FI V8, only fully disconnecting battery for longer term storage as the ECU has to relearn and caused some poor running for the first few full warmups.
(1365 posts)
Date: November 06, 2017 12:41PM
Have a look at your MAF Michael.
I'll bet that you have a buildup of contaminants on the sensor elements.
The smallest amount of dirt can throw these MAF's out of range and never produce a fault code.
Over oiled gauze type air filters will also gum up the sensor
Take a small soft artists brush and some carb cleaner to clean up the sensors. Be very gentle as they are fragile.
The difference in running is sometimes dramatic.
Tremelune
Fat Dog
(2 posts)
04/14/2018 12:33PM
Posted by: Tremelune
Date: April 14, 2018 12:36PM
I don't know about the stumble, but I'm seconding the recommendation for a tender. Much better for the battery than merely disconnected to prevent vampire drain. A battery Tender Jr is like $25...I've got one hooked up to any vehicle that won't be driven in the next few days. Really helps the battery last. If it solves your stumble, it's a free lunch!
Sidecardoug
Doug Rowe
Northern Nevada
(51 posts)
07/04/2012 05:09PM
1969 TR-6 Ford 302
Posted by: Sidecardoug
Date: June 16, 2018 04:13PM
If you are using the factory ECM and fuel injection, this guy may be able to help - I recently contacted him
about reprogamming the ECM for my '58 Volvo / 3.4 Camaro 4L60E to better optimize the shift points to compensate for the significantly lighter weight of the Volvo. He said the ECU SERV # is in the range he can work with. ( Listed on his website - it may take him a week or so to get back to you, as he's pretty busy.)
www.PCMperformance.com
