galotis George Van Horn Collegeville, Pa (35 posts) Registered: 05/13/2014 05:40PM Main British Car: 1980 MGB 1.9L Supercharged, Microsquirt EFI, ESDI. |
Rover 4.0 & Megasquirt
Quote: Edited 1 time(s). Last edit at 06/06/2018 10:41AM by MGBV8. |
Hello, I am new to this board and am looking for information so I don't have to "re create the wheel" . I am very familiar with megasquirt. I have a friend who has a Rover 4.0 /Gems motor. I will be putting this in a 1980 MGB. What I am looking for is a short list.
1) Can I use the fly wheel trigger if I am using a 5 speed vs automatic? 2) looking for any fuel and timing maps to start with. 3) sequential injection any one timing this? And any other info that I might need. Yes I have searched the board, got a lot of info but not to the listed questions. George |
Re: Rover 4.0 & Megasquirt
Welcome to BritishV8, George! I've moved your post from our "MG" to our "Drivetrain" sub-forum to help it get more attention.
You asked: "Can I use the fly wheel trigger if I am using a 5 speed vs automatic?" I don't see why not. Pull up this photo and look at the gold ring that's riveted to an original 4.0 flexplate: [www.roverparts.com] - I don't see why you couldn't transfer one of these rings to the back of a 5-speed compatible flywheel (purchased from someplace like D&D). You'll obviously need eight very accurately placed holes for rivets (or screws), and you might also need to have a flat surface machined onto the flywheel's back side to accept the ring. Hopefully you won't need a spacer ring. I'd entrust the job to my machinist friend - I enjoy every minute I spend hanging out in his shop - and I'd ask him to lighten the flywheel too at the same time. Since both a lathe and a milling machine are required. I'm guessing two hours of shop time. Sounds like fun! "looking for any fuel and timing maps to start with." Several of us have MegaSquirted our BOPR engines, though not with GEMS as the starting point. My Buick 215 has been fitted with 4.0 heads, intake manifold, and injectors - but most everything else is different. I'll attach an MSQ file here as a starting point. (Pull it up in Tuner Studio and you'll be able to see my fuel and ignition maps.) You can review other engine specs here. Not sure if it will help you, but it's something. CurtisJacobsonsBuick215.msq "sequential injection any one timing this?" I'm running sequential, but I won't bother trying to optimize it for awhile yet. (No EGR sensors. Can't afford dyno time. Etc.) More sophisticated guys than me will probably jump in here soon. |
Curtis, thanks for the welcome, I am planning on stripping all the gems8 off. I use GM sensors on my other play toy, so will see what I can use here. Thanks for the msq file. that will be a great start. Am looking at a kit from Trigger-wheel.com
My friend who I am doing this for would like it on the road by 2nd week Sept. tall order but we are going to try. I have tried to call D&D but have no luck, not sure if their still open. Any other good suppliers out there? Need motor mounts, flywheel and bell housing for a T5 or T56, not sure which yet. Nice GT! |
George,
I use squential injection, and there is a noticeable improvement it low speed driveabilty. I've played around with the injector timing table some, however it doesn't seem to make a huge difference on my engine. This could be because I run an open plenum manifold though. I would think that Curtis's set up should get you close as far as fuel and timing maps go. It is similar in overall design and his engine is running well. Bill |
Scott McRoberts: [www.mcrobertsmachine.com]
There are guys in England that frequent the forum attached here [www.v8forum.co.uk] There is also a forum in Australia for some kind of swamp buggies or hillclimbers or some other fringe powersport, can't remember which. They build some insane megasquirted Rover V8s. Happy hunting.
Next problem to solve is the water pump on a 4.0 spins opposite of the crank. Any one deal with this yet.
Just acquired the T5, 1352-169. Working on finding pulleys for the crank, and alternator and idler pulley. looking for 5 or 6 ribbed.
Quote: I have the same one if I recall correctly. It's a Ford T5, which I'm sure you already know. |
"Next problem to solve is the water pump on a 4.0 spins opposite of the crank. Any one deal with this yet."
Can't you just use a Buick front cover with a conventional water pump? |
I think that question is compounded by which oil pump is fitted. That was about then they went to the concentric, crank driven pump. Better in my opinion but bulkier down around the damper. I see no reason why the later engine with the serpentine drive could not be used, but there might be some interference issues to deal with.
with only the crank, water pump and alternator, I am looking at using a idler pulley on the other side. will check interference. I am keeping the 4.0 front cover because I want to keep and use the cam sensor in the cover.
Quote: Jim Stuart did it, but slid the engine back a smidge more. There are pics of his modded engine mounts. [www.britishv8.org] |
Go here - [forum.britishv8.org] - and click on "Send a Private Message".
