ricey
Phil Rice
Chessington Surrey
(34 posts)
07/05/2017 02:19AM
Mgb gt 1975 3.9 rover
Lt77 gearbox position
Posted by: ricey
Date: July 29, 2018 08:29AM
Hi guys
Can I ask the position of the lt77 when looking from underneath?
I have fabbed the existing mountings and cross member and when looking underneath the gearbox is isn’t exactly level with the floor of the car. I would say it hangs about 1” below the floor at the prop shaftt end
My question is should the gearbox be level with the floor?
Thanks
Re: Lt77 gearbox position
Date: August 01, 2018 08:10PM
Pan rail level ? Driveshaft straight ?
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: August 02, 2018 09:18AM
Generally speaking....no!
Engine/xsmn usually has a power angle of, typically, 3 degrees tail down....matching the rear axle pinion of 3 degrees up.
ricey
Phil Rice
Chessington Surrey
(34 posts)
07/05/2017 02:19AM
Posted by: ricey
Date: August 14, 2018 02:57AM
Yep sussed it. I was 15mm out on the new towers on the cross member . so rather than re fan again I got some new cotton reels 15mm thicker and these worked spot on. Now it sits neatly and the gear shift protrudes vertically into the car.
Thanks for input
