Rover v8 identification?
I have recently purchased a 79 MGB with a Rover V8. The ID# on the drivers side of the engine block is 668D00205A. I can't seem to find this # on any ID sites. Anyone ?
Simon Austin Simon Austin Surrey, British Columbia (107 posts) Registered: 10/23/2007 01:44AM Main British Car: 1977 MGB V8 / 1970 MGB GT V8 project Rover 3.5 / Rover 3.5 |
Re: Rover v8 identification?
I’ve got some info in my files, Barry. I’ll see what I can find.
ricey Phil Rice Chessington Surrey (34 posts) Registered: 07/05/2017 02:19AM Main British Car: Mgb gt 1975 3.9 rover |
[www.v8register.net]
Hi Barry this is the link I used tio check mine but I can’t see anything like yours on there, one way to narrow it down is the type of water pump and timing cover. Unless it’s beem changed if you have the later higher pump then that usually denotes 3.9 upwards which is Land Rover and Range Rover sourced Phil |
My list came from Rimmer Bros but has the same numbers as the one Phil posted.
I can’t find your engine number either, Barry. You’re sure about those numbers? |
murray.arnold murray forbes-arnold croatia (16 posts) Registered: 09/13/2018 01:25AM Main British Car: 1973 MGB GT ROVER 3.5 V8 |
Hi guys, where do I find my engine number. I am now interested to find out where my engine came from. I was told my car had a new crate motor in 1988. But who knows. I was told it was a 150hp model. Again, I just don't know.
thanks |
Hi Barry,
That is not a valid engine number. Might it be a 58D or 60D? A pic would be helpful. Murray, The Rover V8 engine number is on a pad between the middle cylinders on the left side. |
