RDMG
Dave R
Northern Virginia
(138 posts)
04/07/2016 08:29PM
1979 MGB 4.6L Rover V8
Des Hammill’s RV8 Oil System Mods?
Posted by: RDMG
Date: October 18, 2018 09:28PM
In How to Power Tune Rover V8 Engines, Des Hammill suggests a few tweaks to the oil system that I haven’t seen discussed here:
Page 100: Drill a smaller .060” oiling hole in the cam bearings 180 degrees opposite the stock 3/16” hole, and use that very small hole instead of the factory hole to restrict oil to the cam, diverting more flow to the main and rod bearings where more flow is needed. Apparently helps keep oil distribution even throughout the engine, even after cam bearings are worn past ideal tolerances.
Page 104-105: Tap the 3/16” valvetrain oil feed holes in the bIock or head and install grub screws with a .040” hole in them to restrict flow to lifters, which can increase engine oil pressure by about 5psi.
Anyone have thoughts on these? I’m about to pull the trigger on a rebuild, and am wondering what the consensus opinion on these modifications might be?
Edited 1 time(s). Last edit at 10/21/2018 07:34AM by RDMG.
(6468 posts)
Re: Does Hammill’s RV8 Oil System Mods?
Date: October 19, 2018 09:05AM
If you've done the other mods and have kept your bearing clearances under .0015" you shouldn't need these mods. I have 45psi at 1500rpm with 5w20 oil.
Blown v8
Bryan Phipps
(71 posts)
03/10/2013 04:52PM
Posted by: Blown v8
Date: October 19, 2018 01:15PM
I did the head "restrictor" mod years before Des's book was out,
I went roller rocker,and didn't need so much oil in the heads
