Des Hammill’s RV8 Oil System Mods?
In How to Power Tune Rover V8 Engines, Des Hammill suggests a few tweaks to the oil system that I haven’t seen discussed here:
Page 100: Drill a smaller .060” oiling hole in the cam bearings 180 degrees opposite the stock 3/16” hole, and use that very small hole instead of the factory hole to restrict oil to the cam, diverting more flow to the main and rod bearings where more flow is needed. Apparently helps keep oil distribution even throughout the engine, even after cam bearings are worn past ideal tolerances. Page 104-105: Tap the 3/16” valvetrain oil feed holes in the bIock or head and install grub screws with a .040” hole in them to restrict flow to lifters, which can increase engine oil pressure by about 5psi. Anyone have thoughts on these? I’m about to pull the trigger on a rebuild, and am wondering what the consensus opinion on these modifications might be? Edited 1 time(s). Last edit at 10/21/2018 07:34AM by RDMG. |
Re: Does Hammill’s RV8 Oil System Mods?
If you've done the other mods and have kept your bearing clearances under .0015" you shouldn't need these mods. I have 45psi at 1500rpm with 5w20 oil.
