Goto Page: 12Next
Current Page: 1 of 2
bberg
Bob Berg
Powell Ohio
(3 posts)
03/15/2012 09:17AM
1980 TR-8 Rover v8 4.6L MCT Costcast block-Wildcat intake
Intake Manifold-Thermostat Housing ...help
Posted by: bberg
Date: March 15, 2012 09:43AM
I have a wildcat spider intake manifold I purchased from Ian Richardson at Wildcat Engineering back in 2006 and now want to use on my triumph Tr-8 with 4.6L engine swapping out the edelbrock.....I never purchased the thermostat housing when I bought it and need any help with where I can find one....I called Ian and he doesn't have any because there were to many options-he also said he is retiring now passing the business on to a colleague...the manifold is similar to the wilpower one available in australia..
thanks
Bob
Re: Intake Manifold-Thermostat Housing ...help
Date: March 15, 2012 11:53AM
Bob, Good luck with the "colleague". Have you checked the manifold for fit ? Mine would not fit any rover or sbb. "Maybe" a rover 4.4L .(aussie) ? I would check Offy remote houusing. Good Luck, roverman.
(6469 posts)
Date: March 15, 2012 02:24PM
Art, what's the deck height difference between the 4.4 (P76) and the SBB 300?
Date: March 15, 2012 06:01PM
Jim and clan. Good question, it's here in our forum-somewhere ? Dan Jones sold mainifold to Oz ? Cheers, roverman.
minorv8
Jukka Harkola
(269 posts)
04/08/2009 06:50AM
Morris Minor Rover V8
Posted by: minorv8
Date: March 16, 2012 02:06AM
I have fitted a Willpower single plane on a 4,6 engine and solved the thrmostat housing problem with std. Rover V8 part. It is not exactly pretty but works.
(6469 posts)
Date: March 16, 2012 11:45AM
I think a SBC thermostat neck might work.
Bill Young
Bill Young
Kansas City, MO
(1337 posts)
10/23/2007 09:23AM
Posted by: Bill Young
Date: March 16, 2012 01:41PM
Making an adaptor would be relatively simple unless hood clearance is a big problem. A piece of 1/2" aluminum plate drilled to both patterns and then countersunk for the lower pattern and you could bolt on any outlet you wanted to match the hose configuration you need. I'd recommend small block Chevy as there are literally hundereds of thermostat housings built for that engine.
bberg
Bob Berg
Powell Ohio
(3 posts)
03/15/2012 09:17AM
Posted by: bberg
Date: March 21, 2012 09:31AM
Thanks for the feedback.....I know that Ian Richardson made two different wildcat spider manifolds-one to fit standard rover v8 heads and the other one that fits his stage 1 & 2 heads which are different.I also talked to the owner of wilpower in austraila and he said he makes all the manifolds and the wildcat spider for Ian as private label -go figure... There is a kilkenny castings water outlet part # W076 that fits the wildcat manifold but it turns toward the distributor similar to Jukka's picture-available in austraila for about $30-I believe std rov v8.I have them looking at matching another housing as well because that manufacture hundreds of them. I did some digging and found a fel pro gasket part # 35097 at advance auto parts that is an exact match for the rover v8 bolt pattern-70mm center bolt hole to bolt hole ....hmmmmm.....says its for ford british, toyota, etc....I checked housings for a ford 4.6L engine and found looking at pictures that there are housings that are 90 degree and straight on....Im in columbus Ohio so I went to jegs store and matched a mr gasket part # 2664 ford housing $12 (lots of options there) that is 69mm hole spacing and can work-little hole widening. I went to ford dealer and found a 2000 ford crown victoria with 4.6l engine housing (motorcraft #RH44) that is straight 90 degree with nipple bleed provision on top and also a 2000 mustang 4.6L sohc water housing 90 deg straight (motorcraft #RH49) that will also work...the motorcraft has flange on the bottom (1/16 inch) where it fits into a slot that has to be taken off but it fits. And my standard TR8 housing from the original manifold also works but the hose is directly at the distributor. I will have the manifold/housing alum coated so I dont want any chrome stuff......
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: February 10, 2019 11:03AM
Dredging up an old one... I'm working on the Astre again and am trying to figure out how to run hoses to the heater core with the Willpower intake. . The return line is on the water pump but there is no provision for a supply line off of the front water crossover where it should be. Can you Tee off of the bypass hose somehow?
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: February 10, 2019 01:35PM
There is also a tapped hole at the drivers side rear of the manifold.. what would this be used for?
minorv8
Jukka Harkola
(269 posts)
04/08/2009 06:50AM
Posted by: minorv8
Date: February 10, 2019 03:20PM
I will check my photo archives. Can't remember how I ran the heater hoses.
minorv8
Jukka Harkola
(269 posts)
04/08/2009 06:50AM
Posted by: minorv8
Date: February 11, 2019 01:44AM
OK found a photo. I used the tapped hole for heater supply and a connection behind the water pump as a return.
Hope this helps.
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: February 11, 2019 10:26AM
Thanks Jukka
So you are essentially using the back port of the manifold through the heater core and to the water pump bypass port and using the heater core as the part of the bypass?
On the stock GM engine the water flowed from the front water ports in the heads through a cavity underneath the carburetor and circle back around to the front on the manifold and exited out of the vertical thermostat housing in the front.
Have you had any cooling issues and does the heater core provide enough Heat?
On my wullpower intake the front thermostat housing crossover has a port drilled for the bypass. You can also see the modifications I had to do to my Kilkenny castings WO58 thermostat housing to get it so it would not Point towards the distributor.
(2463 posts)
Date: February 11, 2019 02:02PM
You could splice one of these in each radiator hose for heater connections:
[www.speedwaymotors.com]
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: February 11, 2019 03:39PM
Any ideas on what that threaded hole at the top of the pump is used for?
minorv8
Jukka Harkola
(269 posts)
04/08/2009 06:50AM
Posted by: minorv8
Date: February 12, 2019 01:25AM
I´ve since gone the EFI route but yes it did work and provided enough heat to the heater core. The only cooling issue was my own fault. My radiator is lower than the engine, expansion tank is higher than the engine. Due to the top hose route I had an air pocket there and had fitted an air bleed connection. I ran a hose from the connection to the expansion tank. Any air would be removed. I thought that when I fitted this manifold I removed the air bleed connection from the top hose. No longer needed... WRONG ! The very test drive showed me wrong big time. So, back to garage and welded a connection back. The expansion tank is behind the engine and you can just about see a hose that has been plugged with a bolt. That is the other end of the venting line.
I have drilled a couple of holes in the thermostat so there is always some by-pass.
This is the current EFi spec. You can see the venting line running from the top hose to the tank (top passenger side). There is another hose running from the radiator to the expansion tank.
Date: February 12, 2019 12:32PM
Jukka, have you noticed the steering get's "very light", when you take-off ?
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: February 12, 2019 01:50PM
Art..You have any idea on what that tapped hole is for on the top of the water pump I have pictured above ?
Date: February 12, 2019 05:24PM
Air bleed, cold side temp sender ? Forum stimulus ?
(4512 posts)
Date: February 12, 2019 09:15PM
No idea. That hole is plugged on my Buick 300 water pump. Tony, as is all the others that I have seen.
Goto Page: 12Next
