mstemp
Mike Stemp
Calgary, Canada
(223 posts)
11/25/2009 07:18AM
1980 MGB Rover 4.6L
Trigger Wheel Mounting
Posted by: mstemp
Date: March 07, 2019 03:30PM
Finally at the point that I would like to move to crank triggered ignition on my Rover 4.6L. It is using a Buick 215 damper and front cover so none of the simple UK sourced kits look to work for the trigger wheel and pick up. While I have seen what Curtis did on his MS3 Pro setup, would rather not have to space out the alternator and water pump. So my question is, would attaching the wheel to the front side of the damper on the outer most circle effect the balance of the motor? Seeing at this outer ring is attached via the rubber to the center section there would be some obvious play but would this be significant to effect the timing and would it hurt the motors balance?
Re: Trigger Wheel Mounting
Date: March 07, 2019 06:37PM
Should be OK. Another option is to drill holes in the pulley to create a tooth pattern if your pulley is dished.
MG four six eight
Bill Jacobson
Wa state
(324 posts)
10/23/2007 02:15AM
Posted by: MG four six eight
Date: March 08, 2019 02:22AM
I have mine mounted to the back side of the outer ring. Works well, if I remember correctly I had to machine the overall diameter of the trigger wheel by .125" to clear the timing indicator on the cover.
There is a couple of pics in my build write up here [www.britishv8.org]
Bill
Edited 1 time(s). Last edit at 03/08/2019 02:22AM by MG four six eight.
mstemp
Mike Stemp
Calgary, Canada
(223 posts)
11/25/2009 07:18AM
1980 MGB Rover 4.6L
Posted by: mstemp
Date: March 08, 2019 07:42AM
Thanks Jim and Bill.
