Anyone able to ID this T5 tag
Date: May 26, 2019 10:55PM
Supposed to be from a 2003 Mustang...
(2463 posts)
Re: Anyone able to ID this T5 tag
Date: May 27, 2019 03:05AM
Rob, Should be a different tag starting with 1352-. If it is a 2003 it will have the 3.35 first. V6's had the T5, the V8's had the T45 with integral bellhousing.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: May 27, 2019 08:01AM
Tried to ID the part no and found this on ebay
Part no. 8R33-7003-BB
2005-2010 Mustang 4.0L V6 New Tremec Transmission with 10 spline, fixed flange, 3.75, 2.19,1.41,1.00, .72, Reverse 3.53
(4513 posts)
Date: May 27, 2019 09:55AM
Don't believe it is T5. Looks to be a TR-3650. What is that digit before the R33?
[www.paladinmicro.com]
ex-tyke
Graham Creswick
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: May 27, 2019 01:19PM
Clearly a Tremec 5-spd. Maybe this will help
[www.tremec.com]
Date: May 27, 2019 09:53PM
Something still isn't adding up. Here's a pic of the transmission. Pretty sure 3650's have integrated bell housings. This one has a separate bell. A buddy of mine bought this for his 302 swap; the tag and this pic are all I've seen so far. Have asked him to send me a side view of it. It does look like a T5 from this angle. The 1st row on the tag is 2R33 7003 BB. 2nd row is TTET1955 10822 A1531
Edited 2 time(s). Last edit at 05/27/2019 09:58PM by rficalora.
ex-tyke
Graham Creswick
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: May 28, 2019 09:16AM
Pretty sure that 2R33 7003 BB is a FORD part no - as a last resort, you can call your local Ford Dealership Parts Dept
(4513 posts)
Date: May 28, 2019 09:24AM
I have seen a number of TR-3650 pics that show that it bolts to the bell housing. It seem the bolts are inside the tranny, though. (Edit. Makes sense to call it integrated, since it doubles as the front cover). Glad I run GM parts. ;)
Now that we have seen the front of the trans, I agree, it is definitely a T5. My understanding is that it had to come from a V6 & the gear ratios are 3.35, 1.93, 1.26, 1.00, .068
That TREMEC transmission tag chart is a couple of years newer than the T5 in question.
Edited 2 time(s). Last edit at 05/28/2019 09:39AM by MGBV8.
(4513 posts)
Date: May 28, 2019 09:49AM
Bolt pattern says Ford & from what I gather, the 7003 means Mustang.
This guy has one, as well.
[forums.corral.net]
ex-tyke
Graham Creswick
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: May 28, 2019 10:53AM
Going by the build date on the tag A1531
A - January
15 - 15th
3 - 2003
1 - first shift
.......which would support the application being a 2003 vehicle.
Easy enough to do an output to input ratio count in all gears to determine the ratios.
Date: May 28, 2019 01:20PM
Still waiting for side view pic, but everything is pointing to T5 from 2003 Mustang as my buddy was told... which is good because he bought it before decoding the tag.
IaTR6
Dennis Costello
Central Iowa
(192 posts)
12/29/2007 02:53PM
'73 TR 6 '97 Explorer 5.0
Posted by: IaTR6
Date: May 28, 2019 02:04PM
From my records: The 94-95 year Mustangs were the last for the T5 behind a v8. Those two years had a longer input shaft and deeper
bell housing to accommodate a revised shifter location. The T5 was used with the V6 after that, and has the longer input shaft as well.
These V6 transmissions are, as referred to before, 3.35 first and a .68 overdrive. These V6 transmissions have the upgraded 300 ft/lb rating.
I cannot tell from the first picture, but i think it shows the domed cover without the neutral switch, which makes it at least a 96 or newer-
well, the cover anyway. So many of these have been built from a collection of parts that it can be hard to tell for sure. (mine is)
They also have the reverse brake, which I have, but the usefulness is lost on me as the old habit of shifting into a forward gear before selecting
reverse just won't go away.
Date: May 28, 2019 06:16PM
Side view. Definitely T5. Looks to have electric VSS so everything seems to be consistent with seller's statement of 2003 Mustang. Just got a text saying he picked it up for just $100 too!
Edited 1 time(s). Last edit at 05/28/2019 06:21PM by rficalora.
(4513 posts)
Date: May 28, 2019 07:02PM
Cool deal! Pretty sure I have the gear ratios right.
ex-tyke
Graham Creswick
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: May 29, 2019 09:49PM
As another check for build year (assuming that Tremec followed the BW dating scheme), there is a build year identifier cast on the top cover . Here's a photo of my spare T5 built in 1990..."90" embossed in the casting.
Date: May 30, 2019 10:44AM
What's cool to me is folks don't seem to have caught on that these V6 T5's are WC spec & same gear ratios as the fox body units. So they're a cheap source of transmissions (as long as the 3.35 1st gear works for you).
ex-tyke
Graham Creswick
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: May 30, 2019 11:53AM
...and the input shaft length matches your bellhousing.
