jaygerding
john gerding
(21 posts)
06/14/2017 09:33PM
Stripped threads 4.0 head
Posted by: jaygerding
Date: February 03, 2019 01:45PM
I have been rebuilding a 4.0 engine from a 1996 Range Rover. I have been having some head gasket problems, and yesterday while installing the bolts, two of the long bolts stripped out the threads from the block.
My question is, what is the accepted way to repair this? I have read elsewhere that some use double helicoils, while others use something called Timesert. These look promising, but the kit for a Rover engine is, frankly, outrageously priced for a one time effort.
I have also read that helicoils can "back out" over time. Anyone had any trouble with this?
Special
ED TESTA
(7 posts)
04/24/2019 09:58PM
Re: Stripped threads 4.0 head
Posted by: Special
Date: May 29, 2019 11:03PM
Timeserts are the way to go. I use them all the time to repair rover blocks. Get rid of the stretch bolts and use ARP studs.
RDMG
Dave R
Northern Virginia
(138 posts)
04/07/2016 08:29PM
1979 MGB 4.6L Rover V8
Posted by: RDMG
Date: June 10, 2019 01:36AM
You can save some money on TimeSerts by buying the pieces separately. As far as I can tell, the only benefit of the Rover-specific kit is a jig to help you maintain alignment while drilling and threading the holes. There’s probably a harbor-freight gizmo that will do the same thing for far less $.
britcars
Phil Ossinger
New Brunswick, Canada
(346 posts)
02/02/2009 07:58PM
1977 MGB Roadster, Rover 3.5 ADVENTURE BEFORE DEMENTIA!
Posted by: britcars
Date: June 10, 2019 07:47AM
What Ed said........................Timeserts are the way to go. I use them all the time to repair rover blocks. Get rid of the stretch bolts and use ARP studs.
quietone
Larry Mimbs
Tennille, Ga.
(93 posts)
07/13/2013 04:22PM
Posted by: quietone
Date: June 10, 2019 03:20PM
I made a jig for installing thread inserts square to deck on engine blocks. With simple adapters, works great for drilling and tapping square to surface on many places. Anyone with a mill can make a similar one. If you like, I can probably send some pictures.
(6469 posts)
Date: June 10, 2019 05:25PM
I did that too. Inserted double helicoils, and still had issues with pulling the threads out of the block. Eventually went to an iron block and that took care of it.
Special
ED TESTA
(7 posts)
04/24/2019 09:58PM
Posted by: Special
Date: June 12, 2019 01:29AM
I have stacks of heads around my shop from rebuilding rover engines and i just have one spare that i use as a template for the drilling.
