NAS1966 Norbert Sliwinski Monroeville (28 posts) Registered: 08/11/2012 05:20PM Main British Car: 1973 MGB GM 2.8 V6 |
DIY Exhaust
Hi All,
I am looking for data for a DIY header and exhaust pipes for my 2.8 V6 for my '74 MGB restoration project. There where a bunch of people who made their own but no one gave pipe sizes i.e. primary and secondary OD pipe diameters. According to my calculations the primary ( header ) pipes should be 1 5/8 ID or 1 7/8 OD and the main exhaust pipes after the collector should be 2 ID or 2 1/16 OD Also I saw one set-up which had a couple of nice rectangular mufflers - does anyone have data for those? . Can anyone concur with these above pipe sizes or which size pipes should I be using? |
Re: DIY Exhaust
IMO, your primaries are too large. Except for all out high RPM efforts, smaller is better. I run 1 5/8" primary headers on a 400hp 350 V8.
[www.sandersonheaders.com] [www.wallaceracing.com] [garage.grumpysperformance.com] |
Re: DIY Exhaust
I used 1 1/2" primaries on my 3.1 headers with 2 1/4" collectors. I got guidance from Headers by Ed when I sized things.
Re: DIY Exhaust
For the mufflers you referred to, check out [spintechmufflers.com].
I use their cruiser series on my car. They are great for clearance, but I wish the sounds was a bit deeper. |
Re: DIY Exhaust
If your 60 degree V6 doesn't have unevenly spaced pulses competing for space in the collectors, you want them to be smaller in diameter than what would be run in an equivalent 90 degree non-flat plane V8. I'll have to check my notes but we are running well over 600 HP through 2 1/2" ID collectors with out 180 degree headers instead of the usual 3 1/2" ID for a 4-into-1 header.
Dan Jones |
Re: DIY Exhaust
Rob,
great to hear the name SpinTech pop up again as it isn't mentioned than much these days. Dyno muffler shootouts and sound clips sold me. Out of app 13 different brands SpinTech was rated 2nd and 3rd behing a 454 on the dyno in Hp & Tq numbers. I run a pair of them now called the 8000 series "Truck RV mufflers 4" x 10.5" x 20" 2 1/2" in / out in aluminized steel on the 68 F250 with 410, 427 heads and intake. Original Doug Thorley headers out back to a custom built 4 piece "X" cross all ceramic coated inside and out. Made a copy of their "X" pipe, [burnsstainless.com]. pissed them off after finding the exact venturi restriction cross sectional area they dyno created. It took 34 pieces of tubing and mandrel bends to complete my exhaust system. A lot of mockup, tack and Mig welding hrs spent. WTH a custom DIY system a one off vs expensive muffler shop hacks. Do not believe these Truck RV's are that quiet, they are rather loud at least with my engine and the exhaust ends out the back. Going silent above 3,200 rpms or 85 mph not pleasing with the cops. Long coned out to 4 1/2" dia long tips. It barks plus causing negative pulses all the way back to the O2 sensors an inch after the header flanges, they scale full lean to full rich at around 2,350 rpm's. Before this a pair of Edelbrock's stainless RPM Series 5510 2 1/2" "LIfe Time" mufflers back in 02, made your eardrums chatter at a certain rpm drone zone hence the swap to Spintechs. Same problem not as bad. Cool sounding Borla's Cat Back SS system on the 95 Disco 1 with a slight drone zone right at 58 to 64 mph in main highway traffic with back set family ending up in 4th vs 5th gear to remove that drone zone. Next step adding Vibrant's SS "Silent Resonators" I have in storage to both vehicles toning therm down a little. I say little I like to apply throttle listening to exhaust music but not that stupid drone. Disco sounds like a 289 with Glaspacks while stirring the stick.....~~=o&o>....... |
