Ported flow #'s for TA heads ?
Dan Jones or anybody ? Serious 4L. motor, "if" I can get the SBF raw forged crank down to 2.8" stroke. art.
Re: Ported flow #'s for TA heads ?
Do you have to go all the way to 2.8" stroke, Art? Rules requirement? Could stop around 3.00" & still have a buzzin' little engine with a bit more grunt.
If possible, make for 4L. limit of SCCA/GT1. Change cam for road courses. Otherwise build to what the crank will task. TR8 5 spd used a Huffaker 10% fifth and Leyland racing 1-4.
Here is a report from Dan Jones over on the V8 Owners Forum. Scroll down 7-8 posts to the one by Daniel Jones.
[www.v8forum.co.uk] |
Here's the info I posted previously. I thought I'd share some numbers for a set of TA Rover heads I had on a flow bench recently. The heads were first flowed in unported form and then ported by Bob Stiegemeier of Stiegemeier Porting Service (http://stiegemeier.com/) in St. Charles, Missouri USA. In addition to the heads, I dropped off a Willpower single plane intake manifold, exhaust header flange, block and assorted gaskets for mock up purposes. I also dropped off an unported Rover 4.6L cylinder head for comparison purposes. This set of heads started as an assembled unported set from TA Performance with 1.94" diameter intake and 1.6" diameter exhaust valves and an upgraded spring package. We started the evaluation by removing a pair of valves from one cylinder. Bob examined the ports, chamber shrouding, seat margins and valve angles and asked me some questions about the engine the heads will be going on (cross-bolted Rover 4.2L with Carrillo rods, Wiseco forged pistons for a street driven Triumph TR8). He also asked if I was going to run EFI (yes) or a carb, suggesting you can get away with larger ports with EFI. Since the heads were assembled, we decided the best bang-for-the buck would be to work around the existing valve job. Looking at the intake ports, Bob noted the as cast port size was plenty large for my application and thought they should go to 250 CFM easily with only minor work. He also threaded a spark plug into the head and indicated he would do a little chamber work around the plugs and polish the chambers. Bob used to do development work on NASCAR intake manifolds and mentioned getting the port floor of the intake manifold to work with cylinder head port floor was especially critical. Bob pulled out some exhaust port templates and asked about the headers I planned to run (1 5/8" primary TR8 tri-ys). Bob said the shape of the exhaust ports looked good but would need to be made wider. I'd previously contacted the developer of the heads, Mike Tomaszewski of TA Performance, and he had the following to say on porting the TA Rover heads: "On the exhaust have him start by opening up the exhaust outlet, make the port wider, The port will respond by doing this. Then have him remove very little to none on the back side of the exhaust bowl. Just blend the machined throat area into the back side. He should end up with a slight bump even, on the back side. Blend the rest of the bowl how he sees fit." The heads were tested at a 28" pressure drop on a SuperFlow 600 flow bench. Intake ports were flowed with a clayed radius around the intake port. No pipe was used on the exhaust except for one test with the stock 4.6L Rover head (noted below). Flow is in cubic feet per minute (CFM) and lift is in inches. Intake valve diameter is 1.94" and exhaust diameter is 1.6". Note that the heads were purchased assembled and Bob worked around the existing valve job. Heads were flowed unported, ported and ported with a 30 degree back cut on the intake valves. Columns are as follow: 1 = out of box intake ports 2 = ported intake, no back cut on intake valves 3 = ported intake, 30 degree back cut on intake valves 4 = out-of-box exhaust ports, no pipe stub 5 = ported exhaust, no back cut on exhaust valves, no pipe stub Valve 1 2 3 4 5 Lift 1.94 1.94 1.94 1.60 1.60 Inch CFM CFM CFM CFM CFM 0.100 67.7 76.8 78.3 47.9 63.8 0.200 105.4 120.4 129.4 70.2 108.5 0.300 143.0 173.1 185.1 102.1 146.7 0.350 164.0 198.7 206.2 114.9 ----- 0.400 185.1 224.2 225.8 126.0 177.0 0.500 220.9 255.9 251.3 137.2 189.8 0.600 225.8 ----- 252.8 140.4 199.4 Bob noted the flow for the ported intake with back-cut valves was for the first one he did. He got closer to 260 CFM peak on subsequent valves. The exhaust port was sized for a 1 5/8" OD header primary (the larger of the two available tri-y headers for the Triumph TR8). For reference, here's what my ported 1964 Buick 300 cylinder heads flowed with 1.775" intake and 1.5" exhaust valves: Ported 1964 Buick 300 cylinder head Lift 1.775" 1.5" Inch CFM CFM 0.100 66 47 0.200 129 104 0.300 174 130 0.350 187 139 0.400 191 146 0.500 196 152 0.600 200 153 I had also previously flowed a stock Buick 300 head with 1.625" intake and 1.312" exhaust valves at 154 CFM intake and 116 CFM exhaust. The unported Rover 4.6L head flowed: Unported Rover 4.6L cylinder head Lift 1.575" 1.350" Inch CFM CFM 0.100 60.2 57.4 0.200 105.4 92.5 0.300 132.4 103.7 0.350 135.5 106.9 0.400 135.5 106.9 (114.8 with exhaust pipe stub) With minor port work, the ported TA Rover heads flow nearly double the stock Rover 4.6L heads. Bob clearanced the chambers to around 42cc then milled them 0.020" to get them to 37cc. He also installed thin wall bronze sleeves in the pushrod holes. The intake valves had sharp edges around the keepers and damaged some of the valve stem seals during dis-assembly so he smoothed the sharp edges and installed new seals. The intake valves (appear to be SI brand) were out of round so Bob cut them to get them round. The exhaust (Ferrea) were round and needed no adjustment. The intake manifold had a low spot on one of the flanges that he welded up and milled back down. The intake and heads were then port matched on the block. He tested the springs with and without the inner springs. With the inners in place, they are 170 lbs on the seat and 400 lbs @ 0.550" lift. With the inners removed, they are 120 lbs on the seat and 280 lbs @ 0.550". Bob said he can adjust the seat pressure with offset keepers once I decided on the cam. Though I'm considering a hydraulic roller, Bob would really like to see me run a solid flat tappet cam with EDM lifters and beehive springs and spin the engine to 8000 RPM. Given the intake port size, he thought I'd want to run a narrower lobe separation angle than the intake valve diameter (to cubic inches ratio) might suggest, along with a bunch of initial timing and a short advance curve. He also suggested 11:1 compression and thought EFI would work better than a carb with the large intake ports. Given the very strong exhaust port, he thought a single pattern cam would be the way to go. He mentioned that while the exhaust would flow even more with a pipe stub, adding a full length header usually gets it back to what the naked exhaust port flows so he likes to flow them without a pipe stub. Bob was really jazzed about the TA heads and lightweight Rover V8. Bob said he could do better on the intake side starting with a bare set of heads (not working around the existing valve job) and noted there was room on the cylinder head to raise the roof a 1/2" and thought that raising the roof, filling the floor and use a larger intake valve, he could get over 320 CFM out of the intake ports. Dan Jones |
Thanks Dan.
How are those heads working out for you? Any issues? Jim |
They are just sitting on the shelf at the moment, waiting for me to decide on a longer term project (do I spring for a Group 44 TR8 body kit). In the meantime, I have a stock short block 4.2L at the machine shop with ported Rover heads. Turns out the new-old-stock short block needs to be align honed. The shop I use doesn't have the machine for that but are looking to purchase one so it may be a bit of a wait. Spending most of spare time on other project cars (Pantera, Mustang, MR2 turbo, Ford 5.0L and T5 swapped Volvo 245 parts hauler). Dan Jones |
I was smitten by the Group 44 TR7/8 with flares when we toured Bob Tullius' museum at Sebring during the 2001 V8 Meet. Best looking version of the Wedgie ever.
Tim Lanocha has certainly built a very sweet one. [www.thewedgeshop.com] |
I "know a guy with Huffaker spares..." Agreed, Tullius did best. My built TA's will be race only, so let the flow bench fly...
I bought a pair of bare Wildcat heads and ported them myself. Heads are now at a machine shop for valve job and flow testing. Iīll keep you posted...
Not really, I doubt that I will ever have enough traction due to limited tire size. I still have leaf springs and making room for wider tires necessitates mini tubs and seriously modded rear suspension. I ran into issues with the engine, I currently have 3 different short blocks in pieces. Just have to decide which will be put back into the car.Oh and I just might replace the gearbox as well... which needs a new crossmember... Itīs a good theing we have aboout 2 ft of snow outside.
If you need to enlarge/change valve reliefs in your pistons, good idea to check valve angle and centerlines. As I recall, Merlins were 13 deg. not std. 10 deg. What transmission ?
My plan is to assemble a totally new short block (+20 forged pistons, 6 inch SBC rods, 90 mm stroke) so I donīt have to worry about the reliefs. Or actually have to but pistons will be new ones.
My head guy seems to have other things on his list, tried to contact him yesterday but no answer :-) R380 gearbox that I rebuilt years ago. |
OK, I finally got the heads back yesterday. Not exactly the way I wanted, the intake valves were supposed to be back cut but they are not. But what I have is a pair of Wildcats, 1.94 and 1.60 valves, bought as bare versions, ported by myself. The chamber size is currently 43.5 cc and will be machined to final size once I assemble the short block. Parts are now all at home but next week will be spent in USA so nothing happening in the garage.
The flow was measured in liters per second at 25" water and I have converted the values to CFM at 28" water. Flow bench was SF600. Lift is in millimeters and 1 mm is roughly .040". I plan to use a solid cam with about .500" lift for starters. lift in mm intake CFM exhaust CFM 1 27,8 24,4 2 51,8 43,3 3 72,0 58,1 4 90,1 73,3 5 109,2 87,4 6 128,7 104,0 7 148,6 120,2 8 163,9 135,4 9 182,3 149,3 10 198,8 160,1 11 213,4 170,4 12 226,0 179,3 13 233,1 185,4 14 239,4 189,4 15 243,5 192,6 My Merlin heads (from Real Steel in UK) are about the same up to 0.300 lift but after that they really are no match. At 0.500 lift the Wildcat intakes flow 50 cfm more and exhaust 40 cfm more. So it is fair to assume some kind of improvement in performance... Backcutting the intakes may improve the low lift flow a bit. |
Great postings Dan as well Jukka, your flow numbers and knowledge one day on this forum surpassed 15 years digging around other forums only gaining 2% of whats on this great forum. Wow finally stumbled unto a forum covering older engines up to the 4.6 litre. Other forums all about the 5.0 LR3's & LR4's about their low mileage failing timing chains blaming the wrong oils used are the problem BS. Then a "but it's a high tech engine the 5.0 vs your antique push rod engine" attitude. Carry on everyone. Carl......~~=o&o>.......
