turbodave
dave cox
(181 posts)
04/30/2018 03:00PM
SD1
10 degree valve locks for the stock valves?
Posted by: turbodave
Date: December 16, 2019 08:18AM
When I say stock valves, I mean oversize but otherwise stock...
I can get the 10-deg locks from www.realsteel.co.uk for £45 but wondering if anyone knows of a US-based part number for a 10-deg keeper that works with the stock valve stem; maybe it is a standard square-cut lock, but I want to be sure for obvious reasons. I've never understood why the groove in the stock Rover V8 valve is so long compared to others I've seen....
(4512 posts)
Re: 10 degree valve locks for the stock valves?
Date: December 17, 2019 11:39AM
No point in using 10 degree lock with lower spring pressures. 10 degree locks are meant for high spring pressures.
Of course, they also require the appropriate valve spring retainers.
turbodave
dave cox
(181 posts)
04/30/2018 03:00PM
SD1
Date: December 17, 2019 04:38PM
I'm going to buy new retainers to suit beehive springs, so that's irrelevant. I guess I'll just buy them and hopefully they will come with a US based part number.
minorv8
Jukka Harkola
(269 posts)
04/08/2009 06:50AM
Morris Minor Rover V8
Posted by: minorv8
Date: December 18, 2019 02:17AM
Dave, have you look at TA Performance ? They list 10 degree locks, part number TA V1434C.
Re. beehives: I assume that you are assembling Rover heads ? Are there currently beehives available that fit Rover heads ? Couple of years ago I tried to find them but had no luck. Even uprated normal springs are hard to find. Rover springs are relatively short, one option would be longer stem valves but that creates other issues.
