donkelly23 Don Kelly Charleston, SC (130 posts) Registered: 07/21/2011 05:13PM Main British Car: 1980 TR7 V8 Z28 FI ECM 4.0 |
Water Pump Hub
minorv8 Jukka Harkola (268 posts) Registered: 04/08/2009 06:50AM Main British Car: Morris Minor Rover V8 |
Re: Water Pump Hub
Intermediate cover is serpentine type, right ? Different pump and pulley and pump rotates in different rotation. Old type pump will not work in intermediate cover. I am not sure if it even physically fits.
If you really need to mate these together a simple adapter plate is needed. Not necessarily pretty though. Or machine a new pulley. Rover used various pumps and pulleys throughout the years and some are most likely NLA. |
Re: Water Pump Hub
Re: Water Pump Hub
That timing cover is made by John Eales. It is designed to be used with SD1 or P6 type water pump, similar to TR8. It is not a factory intermediate cover.
[www.johnealesroverv8.co.uk] Edited 1 time(s). Last edit at 06/16/2020 12:55PM by minorv8. |
Re: Water Pump Hub
I know
I bought it from John |
Re: Water Pump Hub
According to John, that is a SD1 pump and I need a P6 pump
I'm trying to see if I can get an adapter made out of al If not I guess Rimmer Bros for a new pump |
Re: Water Pump Hub
New pump ordered
