teejay terry jones Raleigh, North Carolina (8 posts) Registered: 12/29/2019 01:44PM Main British Car: 74 MGBGT (now) mildly warmed over B. Coming soon 95 3.4! |
No Leaks (I hope)
Hello, I would like to insure (as much as possible) that the new 3.4 build does not leave too
many puddles on the floor. I have the Haynes Manual and would like to know what you would recommend in addition to the information in there for preventing leaks at all the new seals--heads, oil pan, front crank, rear main, etc. Thanks for your help! Terry |
Mickey Richaud Mickey Richaud Townsend TN (198 posts) Registered: 08/25/2015 06:36AM Main British Car: '03 Jaguar XK8 Jaguar 4.2 |
Re: No Leaks (I hope)
Only one I had on mine was at the rear "valley" in the center of the intake manifold. Mine was a new crate engine, and I installed the Edelbrock intake and Bill Guzman's top section.
If the engine has mileage on it, check the rotating surface of the front seal.
If the crank has a groove worn in it, it can be Speedi-sleeved to get a new surface for the seal to run on. [www.skf.com] Had to do this with my Rover V8. Ivor |
