Goto Page: 123Next
Current Page: 1 of 3
small block mopar, road of un-spoken
Date: April 12, 2010 07:39PM
It is an American V8, of which ,"big brother", hoged a Healy. Perhaps we can discuss the finer points of the small block? Thanks, roverman.
MGB-FV8
Jacques Mathieu
Alexandria, VA
(299 posts)
09/11/2009 08:55PM
Re: small block mopar, road of un-spoken
Posted by: MGB-FV8
Date: April 12, 2010 10:21PM
Nice consideration Art.
Awesome engine for anyone that's ever owned a “Mopar” small block from the muscle car era. I've owned a 1969 Dodge Dart GT "340"; it was very competitive against the same cubic displacement from Ford and GM. It also shouted a particular/pleasing sound that would announce its presence from Mopar family. The actual horse power (like most muscle car of that era) was way under advertised (insurance purpose). A very torque orientated engine.
A weak area of the engine could be found around the mains on the block, this area had to be carefully magna-fluxed for cracks before proceeding with an overhaul.
How about an MG conversion with a 340 "SIX-PACK" with aluminum heads. I don't know the engine dimensions or weight but I imagine that it would be close to the early small block Chevy but heavier than the small block Ford.
Date: April 13, 2010 01:47AM
I had a 318 in a '71 Valiant... my first car... and of course I absolutely loved it! It pulled well, and it proved very durable. I think almost all 318's came with 2-barrel carbs, which was just fine.
Depending on the British sports car, the distributor location (at the back, similar to SBC) might be problematic.
What 5-speed transmission would you pair up with a 273/318/340? Dodge put some 318's in early Dodge Dakota pickups... how many of those (if any) got 5-speed transmissions? Which make/model transmission did they use?
74ls1tr6
Calvin Grannis
Elk Grove,CA
(1151 posts)
11/10/2007 10:05AM
Posted by: 74ls1tr6
Date: April 13, 2010 10:46AM
Back when I was researching an engine to replace my" frozen TR-250 engine", was looking at the Dodge 5.7 Hemi engine. I have one in my 2004 Durango.
I did change all "16 spark plugs" once, which took me awhile. I wanted to do a few things to help out with the gas mileage. The Durango weights in the 6 thousand pound range, so to me seemed a little gutless in stock form, until the gas pedal is on the floor. 1 changed the exhaust system for more flow. 2 installed a large air intake. 3 installed a throttle body spacer. 4 installed a stage 2 chip..... This resulted with wonderful throttle response, (No more gas pedal to floor anymore) when mashing gas pedal to the floor resulted in a huge launch. On a freeway trip, 22 mpg @ 75mph. I believe with a 5 speed auto.
So was looking into using this engine in my TR6. Dodge didn't have a stick transmission that I could find that would work for my application. Didn’t want an auto transmission, ended up with Ls1/t56.
I know the 5.7 Hemi engine would be very fun in a Tr6, as for fitment didn’t get that far, weight, and measurements. I don't think the messurements are that far off from the Ls1. Not knowing, weight would be faily close.
345hp/375tq without the MDS model
Bore x Stroke 3.92 x 3.58 in, 99.5 x 90.9 mm
Valve System pushrod, 16-valve, hydraulic roller lifters
Block Construction cast iron, deep skirt, cross-bolted main caps ------- maybe a little heavy here!
Centerline of crank to head deck face 9.3 inches
Centerline of crank to centerline of cam 7.4 inches
Centerline of crank to oil pan rail 2.6 inches
Overall block maximum deck width at deck face 18.3 inches
Overall block height from
oil pan rail to top of water outlet 15.4 inches
Overall engine length 21.1 inches
Compression Ratio 9.6:1
Combustion chamber volume 84.9cc
Intake valve angle 18 degrees
Intake valve head diameter 50.8mm, 2.00 inches
Exhaust valve angle 16y.5 degrees
Exhaust valve head diameter 39.4mm, 1.55 inches
Oil Capacity 7 qt., 6.6L
Weight (includes induction, wiring harness,
auto-trans flexplate and exhaust manifolds,
but not accessories) 485 lbs
Ignition Two spark plugs per cylinder
Just some more info, throttle body was 6" above the intake, around 33" to pan, apox from manifold 27" to pan, being fairly tall. Wonder if they have lower profile intake setups?
Wow! "sorry" for the dirty engine photos.
Rear sump oil pan! This Durango is a four wheel drive.
26" wide!
Edited 1 time(s). Last edit at 04/13/2010 11:53AM by 74ls1tr6.
Re: small block mopar, well spoken
Date: April 13, 2010 11:34AM
Clan thanks for response. My "concept car", is a hot, 318"+ in a Jensen Healy. Supra 5 spd. should be ok. Which irs.? Maybe Mazda. Tuners say good to 500 hp.? Distributor in rear ,is a plus for this swap, clears the sloping hood. Stroker kits are"chevy cheap", from Flatlander.Edlebrock heads/intake, 400 lbs? The 420"/340, goes in my 67 cuda coupe. You can "peep" the sbf./Healy, for sale in JHPS, market place, for why not a Ford swap,(2 holes in the hood).This is about what Chrysler/Jensen, "could" have built. roverman.
Edited 1 time(s). Last edit at 04/13/2010 11:39AM by roverman.
Re: small block mopar, road of un-spoken value
Date: April 13, 2010 02:53PM
Some would consider,$3,100 for a bare 340 block, a bit much. I would tend to agree. 318's and 360's= dime a doz.How cheap ? Scat 4" stroker kit, rated to 700 hp at up to 7,200 rpm. cost $1325,( crank,rods,forged pistons,moly rings, internally balanced, including bearings ).I think we're talkin 420+ inches at less than 1 lb/in. ?Ported "Edlebrocks", are flowin just over 300 cfm.Did I say, Monster Torque? Got "tubs" out back ? roverman.
Edited 1 time(s). Last edit at 04/13/2010 02:57PM by roverman.
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: April 13, 2010 07:07PM
I have a racing friend who runs a 408 (4" stroke) mopar smallblock in a Dart with a Liberty built new process 4 speed.. The car does wheels up launches and runs mid 10's...
Imagine the possibilities. ;-)
Date: April 13, 2010 07:44PM
Thanks Tony, let's see the "other" 340 do that ! I'm thinkin, your friend got, "tubs", out-back. Make no mistake, I really dig the Rover V8, but "this", is Mopar-personal. This could be like "Mopar/Jensens", answer to the Sumbeam Tiger, only better.
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: April 13, 2010 08:25PM
Art.. the car is stock bodied and is not tubbed.. a 10" slick thats it.
oh yeah.. its a 73 Duster.. not a Dart.
Edited 1 time(s). Last edit at 04/13/2010 08:35PM by hoffbug.
Date: April 13, 2010 09:02PM
I'm thinkin, pushin a"leetul" more air thanna Healy? Bout' 3,200 lbs ?
Greg55_99
Greg Williams
(102 posts)
11/01/2007 07:12PM
Posted by: Greg55_99
Date: April 14, 2010 09:32PM
Yep, Supra Turbo 5-speed with a Dodge Dakota 3.9L V6 bellhousing:
http://i20.photobucket.com/albums/b226/2E151/My%201987%20RX7%20Sport/201-0152_IMG.jpg
[www.slantsix.org]
New generaton Hemi uses the same bolt pattern.
Greg
small block mopar, mofun Healy
Date: April 15, 2010 06:50PM
Greg, thanks for the hot tip. "Lakewood" starts at about $280, 1/4" steel and not even a scattershield. I'm thinkin "Dakota" is alum. ? I like alum. I'm also thinkin,5 spd. is up to the task, 2300 lbs and 400 hp ? Ok, so it looks like we got motor,bh. and 5 spd combo, which irs.? Is RX7 really strong enough ? Nissan or Infinity a better/stronger choice ?"May" push the front wheels forward to 92" wb. Looking for near 50/50 frt/rear and excellent handling. Jensen Healy Hellfire ?
Edited 1 time(s). Last edit at 04/15/2010 11:10PM by roverman.
Re: small block mopar, road of more cubes
Date: April 16, 2010 07:38PM
Looks like best bang per buck is 360, "Magnum" block for oem. roller cams and nickle content in block. Thicker cyl. walls than 340". Much easier to get. 406+ inches. Healy Monster II ? roverman.
Date: April 18, 2010 02:45PM
Greg, Did I read correctly? The what year?, Dakota V6 bh. will bolt-up to Supra 5 spd., 9 bolt/2 dowel box ? I'm finding "zip" at this point. I'm ready to buy. Thanks, roverman.
Greg55_99
Greg Williams
(102 posts)
11/01/2007 07:12PM
Date: April 18, 2010 04:57PM
Hi Art.
I'm showing 94-99 Dakota 3.9L V6 bellhousing. That will bolt right up to the 87-92 Supra Turbo R154 5-speed. Be advised, this combo takes an 11" flywheel. If you have a 273-318-340, you can use the stock 3.9L V6 flywheel. The 360 requires the truck flywheel.
[board.moparts.org]
Also, the R154 is quite wide. Some tunnel work may be required.
Greg
Date: April 19, 2010 01:50PM
Greg and clan. Looks identicle to "pattern" on my W58 Supra box. Turbo? How to tell ? Stamped numbers somwhere ? Over in that Mopar forum, their suggesting truck and little 4 cyl diesel tran's. I'm suspicious of the ratios .Thanks, roverman
(2463 posts)
Date: April 19, 2010 04:46PM
Art, W58 is smaller pattern. You need R154. There was a long thread a while back on the differences. Greg knows his stuff on what fits what! Go with the years on Dakota bell and Supra (Turbo) tranny Greg gave.The ratios on the R154 are just right.The Mopar forum is talking about other bellhousings with that pattern, not tranny's.You need the Dakota (AX15) front bearing retainer sleeve and Dakota slave also.Sounds like a longer pilot bushing,too.
Edited 1 time(s). Last edit at 04/19/2010 04:48PM by mgb260.
Date: April 20, 2010 12:05AM
Clan, I've read of the W58 being quite durable behind V8's. 400 hp. in a 2300 lb. car ? I see 9 bolts and 2 dowels in"Dakota" bh. ,bigger circumferance than the W58 ? No luck so far with "jdm's" for R154 box. Why not just "spring" for the Lexus 6 speed ? Suggestions ? Thanks, roverman.
(2463 posts)
Date: April 20, 2010 12:32AM
Art, Comparison of small(W58) and big (R154)Toyota pattern.
(2463 posts)
Date: April 20, 2010 01:03AM
Art, Another tranny option would be Colorado/Canyon 2WD MA5( same as Solstice and Skye roadsters except for shifter location, used behind 400 HP Mallet LS V8 conversions)Toyota large bell pattern but familiar SBC input splines and output like the old Muncie 4 speed. Lower first gear about 3.75 VS. 3.25 for R154. Picture shows one adapted to GM bell. Quite a few on car-part.com, nationwide as low as $250.
Edited 5 time(s). Last edit at 04/20/2010 05:30PM by mgb260.
Goto Page: 123Next
