woodbeare1
Edward Hammond
(1 posts)
11/14/2020 08:26AM
Retrofitting a Carb and dizzy to a efi Thor 4.6 v8
Posted by: woodbeare1
Date: November 14, 2020 09:24AM
Hi, I'm at the start of a project, and have a couple of choices I have an Ex-SD1 3.5l with edelbrock carb and manifold and an ex-discovery 4.6l with the Thor fuel injection system but no loom or ECU. I wanted to transplant the carb on to the 4.6 but the 4.6 has no dizzy, I've taken off the front cover but the 4.6 cam has no dizzy drive on the camshaft and the shaft itself is shorter than the 3.5l cam.
Will swapping camshafts work or should I look for an aftermarket cam with a dizzy drive??
tr8
Paul MacDonald
Canada
(40 posts)
10/25/2008 04:07PM
TR8 Coupe Rover 4.0
Re: Retrofitting a Carb and dizzy to a efi Thor 4.6 v8
Posted by: tr8
Date: November 14, 2020 09:45AM
folowing
mstemp
Mike Stemp
Calgary, Canada
(223 posts)
11/25/2009 07:18AM
1980 MGB Rover 4.6L
Posted by: mstemp
Date: November 15, 2020 01:40AM
Yes new cam, timing cover and oil pan with the old carb manifold dizzy etc. Worked fine for me over 10 years.. Then switched back to EFI 14 CUX version on mine. Or back date yours to the 14CUX manifold etc. Or stay distributorless and use mega jolt for ignition, carb manifold.
Edited 1 time(s). Last edit at 11/15/2020 09:17AM by mstemp.
(4514 posts)
Date: November 15, 2020 09:34AM
And a pulley spacer for the long nose crank?
