John Hamilton John Hamilton Navarre, FL (23 posts) Registered: 10/28/2009 11:18PM Main British Car: 1965 MGB 1840 cc MGB |
4.0 crank grinding
Just wondering if I can turn down a 4.0 crank from 2.185" down to 2.1" so I can use Chevy rods? Will this compromise strength in a 7000 RPM race motor?
Re: 4.0 crank grinding
Shouldn't
My stroker crank has TVR sized rod journals (narrow) and the rod big end width is 19,4 mm ( just over 3/4"). They needed a bit more machining. Also the bearings had to be machined narrower.
Hi John, First off, you have verified all manner of components to get you max power at 7k rpm. ? If so, by all means, 2.100 journals. Don't assume taking .050" off each side of big end of rod will put end, in center of bore . Use bigger fillet on journals, if possible. If 3/8" bolts, use AP 2000.
What is your hp. level ? Don't expect your cast iron crank to live many happy racing miles, at hi hp. and rpm. Good luck, Art. |
