Re: Rover SD1 V8 power steering
The pump has the reservoir built into it. Remove the black cap and you will see that it has the dip stick built in. I have always used ATF in the TR8/SD1 pump. Some people recommend the Lucas power steering pump fluid, but I don't know where to get it. If you need any parts, I have a complete SD1 subframe and power steering rack in the basement gathering dust.
