Roadcraft bellhousing
Does anyone have any experience with Roadcraft and their BOPR-to-Ford T5 bellhousing? I've emailed to see if they ship to the U.S. and also asked about the input shaft length this bell is intended to accommodate, and so far only gotten crickets. Yeah, I'm aware D&D sells a bell and also adapter plates. This would be a direct bolt-in with no adapters to mess with.
Full disclosure, I have a 2002 Chevy T5 from a V6 F-body. This is a Ford-pattern case with a long input shaft and a factory hydraulic throwout bearing. Trying to mate this to a 1962 215. I suspect that in any case I may require a non-standard thickness spacer plate. This T5 has a unique bearing retainer that accepts the HTOB. [roadcraftuk.co.uk] |
Re: Roadcraft bellhousing
Bill Guzman and D&D have the Ford to GM bellhousing adapter. Or you could do this:
[www.mgexp.com] Edited 1 time(s). Last edit at 04/30/2021 11:13AM by mgb260. |
The other interesting thing I found is that the McLeod Steel flywheel (from TS Automotive) is 1.1" from mounting face to clutch plate face, whereas the SD1 (and I assume all others) cast flywheel was 1.2".
Not much of a difference, but makes a difference when setting up the throw-out bearing positon (or specifically the concentric slave). I'm going to use a .060" shim that Landrover used between the flex plate and crank behind the steel flywheel, and also get the cast flywheel (for the spare engine) skimmed a little to bring the distances a little closer to the same as the steel. |
