phongshader Justin Brown Ca (63 posts) Registered: 02/19/2010 04:03PM Main British Car: Locost Lotus 7 2.3 Duratec |
Rover/Buick lifters in Olds Block?
Will Rover/Buick lifters in fit/work in an Olds block?
Re: Rover/Buick lifters in Olds Block?
Should be the same. Always use new lifters with a new cam and same places they were on a used cam.
how about Buick 350 lifters?
If I'm running stock oiling will the 350 lifters be compatible? I'm going to be running a crower 50233 cam
Product ID: TA_1405J JOHNSON HYD. LIFTER '70/UP 350, 455 `70 & later (Johnson lifter) Price: $135.00 or Product ID: TA_1406 HYDRAULIC LIFTERS PRE 1970 Hydraulic Lifters that fit ALL V8 1956-1969 Engines Price: $280.00 Edited 1 time(s). Last edit at 06/15/2021 04:32PM by phongshader. |
Certain SBC lifters are also compatible.
Would stock lifters work with a spicy cam or would I need to go with something that won't pump up? I'm not going over 6k rpm. I've always used anti pump lifters but they are hard to get at the moment. Something like these? [www.summitracing.com]
Edited 1 time(s). Last edit at 06/16/2021 02:08PM by phongshader. |
Anti pump up lifters are just leaky lifters. Prone to tap. If you want a 6k or higher redline it's best to fit heavier valve springs.
