Johntownsend47
Jack Townsend
(6 posts)
07/10/2021 04:40PM
PCV Valve Setup
Posted by: Johntownsend47
Date: August 08, 2021 11:53PM
Does anybody have any recommendations on a better PCV valve setup for a Ford 347? Every time I run the engine, oil bleeds out from the where the breather meets the valve cover and I’m not sure if it’s from a bad seal (I’ve tried replacing the seal) or a bad setup. Any recommendations would be greatly appreciated!
(6469 posts)
Re: PCV Valve Setup
Date: August 10, 2021 10:25AM
I use one from a 60's 350 chevy.
(1365 posts)
Re: PCV Valve Setup
Date: August 10, 2021 01:33PM
Firstly Jack you need to have some sort of baffle inside the valve cover to separate out the oil before it gets to the pcv.
The breather that you are using should draw air from the air cleaner, it wasn't designed to feed the pcv.
The pcv should be on the opposite valve cover from the breather and go into the valve cover directly.
Re: PCV Valve Setup
Date: August 14, 2021 10:30PM
I just learned something; have apparently had mine wrong all along. I have a PCV going to manifold vacuum but my breather is the type that I learned from above should be going to my air cleaner. Currently it just has a hose that vents to the ground. At least it doesn't drip because it's right over my steering shaft and there's never any oil on that. But sounds like I need to reroute it to the air cleaner base!
Thanks for the info Fred!
(1365 posts)
Re: PCV Valve Setup
Date: August 20, 2021 01:30PM
No prob Rob.
With a working pcv valve in the system that vent hose is actually sucking dirty air into your engine.
That's why it needs to go to the air cleaner.
