Goto Page: 12Next
Current Page: 1 of 2
turbodave
dave cox
(181 posts)
04/30/2018 03:00PM
SD1
Chevy lifters . . .
Posted by: turbodave
Date: September 23, 2021 11:31AM
So If I was planning on buying custom adjustable pushrods anyway, is there any reason I shouldn't just go ahead and use GM lifters?
A local guy has offered me two boxes of isky 202-HY that have been on his shelf for 10-15 years, so these are likely to still be of a good quality.... It just seems like the better "future proof" solution rather than Rv8 specific units?
Using a 50232 cam btw.
Edited 1 time(s). Last edit at 09/23/2021 11:33AM by turbodave.
(1365 posts)
Re: Chevy lifters . . .
Date: September 23, 2021 12:22PM
I have used the "chevy" lifters many times in the rv8 with good results.
There are some differences to be noted though.
The pushrod seat in the chevy lifter is around 0.050 inches deeper than the rv8. This means that you have 0.050 inches less preload
on the lifter if everything else remains unchanged.
The chevy lifter oils the valve train through the pushrod the rv8 does not. On some styles of aftermarket lifters the lack of this oil release to the valve train can cause the lifter to pump up.
The rv8 lifters have a hardened steel "foot" that most aftermarket lifters don't have. This gives the rv8 lifter a longevity advantage.
Some of the chevy lifters have the oil supply relief, around the circumference of the lifter, in a slightly different spot. On a higher lift cam or a reground cam this can expose the relief and cause an oil pressure loss.
So depending upon your specific combination the chevy lifters may work well. Measure everything and confirm the fit and you will be fine.
Re: Chevy lifters . . .rollers = better
Date: September 23, 2021 02:31PM
jus' sayin, Art.
joe_padavano
Joseph Padavano
Northern Virginia
(157 posts)
02/15/2010 03:49PM
Posted by: joe_padavano
Date: September 23, 2021 06:38PM
The other concern is the location of the oiling band in the lifter. I can't speak for Buick, but I know that many aftermarket Chevy lifters have an oil band that can become exposed in an Olds or Pontiac block when used with certain cam profiles. Of course that means zero oil pressure. Hilarity ensues.
With any aftermarket or cross-breed lifters, be sure to test assemble the motor and check for that oil band.
(2463 posts)
Date: September 23, 2021 08:56PM
Buick 350 V8 lifters oil band is perfect.
minorv8
Jukka Harkola
(269 posts)
04/08/2009 06:50AM
Morris Minor Rover V8
Posted by: minorv8
Date: September 24, 2021 01:08AM
I have used Crane 99284 lifters in my engines.
joe_padavano
Joseph Padavano
Northern Virginia
(157 posts)
02/15/2010 03:49PM
Date: September 24, 2021 08:53AM
"Buick 350 V8 lifters oil band is perfect."
Agreed, but I assumed the OP was asking about using inexpensive SBC lifters.
(2463 posts)
Date: September 24, 2021 01:32PM
Joe, if you go to an auto parts store and check, I don't think you would see much price difference between Chevy or Buick lifters.
mstemp
Mike Stemp
Calgary, Canada
(223 posts)
11/25/2009 07:18AM
1980 MGB Rover 4.6L
Posted by: mstemp
Date: September 24, 2021 08:08PM
If they work.....these seem cheap enough.
[www.rockauto.com]
(1365 posts)
Date: September 24, 2021 08:53PM
If I'm reading it right . The lure is the NOS part. Lifters that were manufactured before the flat tappet world fell apart.
I don't know if the aftermarket has got a grip on their metallurgy yet, but it was pretty miserable a few years back.
In my opinion (the lovely Lynne said I could have one, this one time) no flat tappet engine should be run without Vizards Oil Extreme concentrate. I have not had a single failure since using it. Either it's really good or that voodo stuff I'm doing in the back yard is working.
Live like you mean it
Date: September 25, 2021 09:15AM
I've begun using STP oil treatment.
minorv8
Jukka Harkola
(269 posts)
04/08/2009 06:50AM
Posted by: minorv8
Date: September 26, 2021 02:07AM
I use diesel engine motor oil. It's supposed to have higher ZDDP (or whatever) content than gas engine oils. And run-in additives with new cam.
Spitfire 350
Phil McConnell
Perrysburg, OH (Toledo area)
(257 posts)
01/11/2010 09:19PM
74 Spitfire 350Chevy
Posted by: Spitfire 350
Date: September 26, 2021 01:17PM
I use Valvoline VR1 racing oil, it's supposed to be high zinc. The cam and lifters were broke in back in 1997, so far so good.
88v8
Ivor Duarte
Gloucestershire UK
(1041 posts)
02/11/2010 04:29AM
Posted by: 88v8
Date: September 27, 2021 04:30AM
Racing oil... has a low detergent content so it soon gets dirty. Fine if it's changed frequently, but not fine for the usual intervals.
I use Lucas Classic & Hotrod, a street oil with a high zinc content. [lucasoil.com]
STP.... gosh that takes me back to the late 60s... the super gloopy stuff in a tin with a pull tab..... I used that in my first car, carried a can around and when the oil light came on I stopped and poured in another can...
Ivor
Edited 1 time(s). Last edit at 09/27/2021 04:31AM by 88v8.
(4512 posts)
Date: September 27, 2021 10:06AM
STP oil treatment for what purpose, Jim? From what I have read, that bottle does not have anywhere near enough ZDDP to raise the level in an engine. Most (maybe all) oil additives are snake oil.
If not using synthetic oil, Castrol Classic 20W-50 or Valvoline VR-1 20W-50 would be my choice.
Or, maybe we should be using a 10W-40. Interesting paper, "The selection of motor oil for classic Minis":
[www.widman.biz]
Date: September 27, 2021 10:19AM
I looked at it Carl, on Steve's recommendation and it looked like it was enough.
(2463 posts)
Date: September 27, 2021 02:49PM
There is a "High Mileage" STP that has a higher Zinc content. That is what I used with Valvoline MaxLife 10-30in my old truck. Amzoil full synthetic in the new Ecoboost. Back to lifters. If you pay the extra money I think Johnson lifters are the best. Compare the oil band and hole on the Chevy vs Buick and you will see at high lift the oil. band and hole will be exposed above the lifter bore.
(4512 posts)
Date: September 27, 2021 05:01PM
Where are y'all finding actual numbers, percentage or PPM for STP?
88v8
Ivor Duarte
Gloucestershire UK
(1041 posts)
02/11/2010 04:29AM
Posted by: 88v8
Date: September 28, 2021 05:14AM
Well, here [forums.hybridz.org] it says STP has 5ppm, if that true it's not going to do much for you....
Lucas Hotrod & Classic -.... 2,100ppm [www.lucasoil.co.uk]
Pretty impressive that they publish all the info, you don't have to wheedle it out of their Marketing Dept.
Ivor
Date: September 28, 2021 08:23AM
IDK, I just looked on the bottle.
Goto Page: 12Next
