Goto Page: 123Next
Current Page: 1 of 3
62Healeyhacker
Jerry Jackman
(19 posts)
04/11/2009 10:58PM
No oil pressure on rebuilt 215
Posted by: 62Healeyhacker
Date: April 30, 2019 12:41PM
Still zero oil pressure when I spin the pump through the distributor shaft. I have replaced the front cover and oil pump. What are the most likely causes? (I may have not gotten all the air out when I forced petroleum jelly into the pump.)
Also: I added the steel shim to bottom of pump to eliminate the wear problem. In doing so i made is impossible to change the oil filter without loosening a motor mount and lifting the engine a bit. ( i'm using the shortest filter that fits.) The pre'94 Rover V8 has a pump cover which faces directly forward. Yet I have never seen a 215 Buick using this. Any ideas? ( D and D doesn't list the swivel mounts on their website any longer.)
Any suggestions greatly appreciated.
(4511 posts)
Re: No oil pressure on rebuilt 215
Date: April 30, 2019 03:21PM
How did you force the petroleum jelly into the pump? Did you take it apart & pack it?
62Healeyhacker
Jerry Jackman
(19 posts)
04/11/2009 10:58PM
Date: April 30, 2019 05:24PM
It was done two years ago. I believe the new pump was installed in the new front cover after it was on the engine. I recall the difficulty
with the petroleum jelly because I was on my back in my garage.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: April 30, 2019 06:12PM
Are you driving the distributor shaft/pump in the CW direction when priming?
tr8todd
Todd Kishbach
(390 posts)
12/04/2009 07:42AM
Posted by: tr8todd
Date: May 01, 2019 06:04AM
Had a similar problem on a fresh rebuild once. Turned out the gasket on the pickup tube shifted and was covering the hole in the tube. Only one bolt went there the holes in the gasket. Pull the cover and repack the pump before you try anything else. Another trick is to over fill the sump with oil. The higher the oil level, the easier it is to lift the oil with the pump. Get it high enough and it will fill the pump on its own. Fill the filter with oil before you try and prime the pump.
(4511 posts)
Date: May 01, 2019 09:23AM
Check that your oil pressure relief valve is assembled correctly. Mine wasn't.
Don't go by what is listed or not listed on D&D's website. Call them.
88v8
Ivor Duarte
Gloucestershire UK
(1041 posts)
02/11/2010 04:29AM
Posted by: 88v8
Date: May 02, 2019 04:16AM
Few years ago replaced the gears in my pump, then same as you, couldn't get any pressure.
Turned out the paper cover gasket was too thick.
I got a replacement from ahhh, JE Engineering I think it was, that fixed it. Oil pressure in a couple of seconds with the drill.
As said, fill the filter first.
The petroleum jelly does dry out, needs to be packed well in.
Ivor
(4511 posts)
Date: May 02, 2019 10:55AM
Yes, the gasket sets the clearance between the gears & the housing.
62Healeyhacker
Jerry Jackman
(19 posts)
04/11/2009 10:58PM
Date: May 03, 2019 04:12PM
Thanks for the multiple suggestions.
I have a hunch the gasket where the filler tube attaches leaks air. I will try that first. I hate to pull the cover again but may need to do it to check the pump to face clearance and to get fresh petroleum oil fully packed.
Yes I have been spinning the shaft clockwise. Got something right!
62Healeyhacker
Jerry Jackman
(19 posts)
04/11/2009 10:58PM
Date: May 08, 2019 05:06PM
Here's what I have tried, without success.
I removed the filter and pump cover. With the gears down I packed the chamber with petroleum jelly. I loaded the shaft with jelly and the driven gear. Also stuffed the other gear with jelly. When I pushed them up into the chamber I wiped off the considerable excess petroleum jelly.
Using a "metric" pump cover from Silver-seal I screwed the cover and filter up tight.
Spinning the pump shaft drive clockwise I could feel the strain as the pump spun the jelly. I had high hopes that it was sucking through the pump then pushing the oil into the block. STILL NO PRESSURE!
I pulled the pan to check the gasket where the oil tube connects to the block. Not a problem.
I have ordered a new oil pan gasket.
Now what?
minorv8
Jukka Harkola
(268 posts)
04/08/2009 06:50AM
Morris Minor Rover V8
Posted by: minorv8
Date: May 09, 2019 05:05AM
I recently primed my engine. I have never used jelly, simply ran a drill as long as it primes. This time it took quite long, maybe a minute or two. But primed anyway. I donīt know for how long you have tried but it may take some time.
MG four six eight
Bill Jacobson
Wa state
(324 posts)
10/23/2007 02:15AM
Posted by: MG four six eight
Date: May 12, 2019 01:32AM
I made an engine pre-luber out of an old brake pressure bleeder tank. Basically I put motor oil in it instead of brake fluid and then made an adapter fitting to connect where the oil pressure gauge sender (or pipe) attaches to the pump. Works well and pre-lubes the entire engine as well as priming the pump.
(6468 posts)
Date: May 12, 2019 11:40AM
You could also use a speed-sprayer for that. I haven't, but it wouldn't be hard to do.
40indianss
don foote
(83 posts)
08/01/2013 04:35PM
Posted by: 40indianss
Date: May 13, 2019 12:04AM
Please enlighten me. What is a speed sprayer?
(6468 posts)
Date: May 13, 2019 08:48AM
Sorry, Speedy-Sprayer. Huh, couldn't find it. Maybe that was just a colloquialism. Here ya go:
[www.youtube.com]
40indianss
don foote
(83 posts)
08/01/2013 04:35PM
Date: May 13, 2019 11:38PM
Might be a specific store brand or manufacturer and picture was worth a thousand words. I have several different iterations in my shop. Thanks for the info and should be simple to adapt
Young olds
roger parkey
Washington state
(95 posts)
05/02/2018 07:07PM
Opel 1900 sport coupe 1975 Oldsmobile 215
Posted by: Young olds
Date: May 30, 2019 01:43AM
I had to replace my front cover and now my engine only has about 25psi cold, previously I had about 70. I ran the pump with a drill until it sprayed oil out of the remote oil filter port. Could I be suffering from a priming issue? I did not know about packing the pump with jelly
88v8
Ivor Duarte
Gloucestershire UK
(1041 posts)
02/11/2010 04:29AM
Posted by: 88v8
Date: May 30, 2019 04:42AM
New cover, or used?
I think you have to look at the pressure relief valve, and the clearances in the pump. Including, as I mentioned, the thickness of the cover gasket.
[www.v8wizard.com]
Unfortunately, he doesn't say what the thickness should be, but I do know that too thick destroys the pressure.
They prime easier with jelly, but once it's primed then it's down to clearances.
Ivor
Young olds
roger parkey
Washington state
(95 posts)
05/02/2018 07:07PM
Date: May 30, 2019 09:18AM
I did some reading and believe you are correct. It is a used cover with remote oil filter adapter plate.
(4511 posts)
Date: May 30, 2019 01:11PM
This for Buick 225 V6, but should be the same or very close for the Buick/Olds/Rover aluminum V8s.
Quote:
The Specs for End Play clearance are .0023-.0058. Obviously tighter is better and I like to see them at .002-.004 max. T.A. Performance sells a gasket shim kit # TA-1704 that helps to attain those close specs. If the gear bore side walls are grooved or if worn to the point whereby the clearance between the gears and wall exceeds .006-.007 thousands it may be time to think about getting another timing cover.........Spec for side clearance is .003-.005.
[www.earlycj5.com]
Goto Page: 123Next
