cobriata Eric Williams Texas (1 posts) Registered: 02/16/2016 11:12AM Main British Car: 1971 MGB Buick 300 |
Buick 215 300 weight for aluminum heads and intake vs iron counterparts
For all you Buick fans that can not get ahold of all of those 1964 Buick aluminum heads and was wondering the weight difference, I hope this helps.
Re: Buick 215 300 weight for aluminum heads and intake vs iron counterparts
Aluminum has about 1/3 the density of cast iron, so aluminum bare heads and intake will weigh about 1/3 as much as cast iron.
Actually the aluminum heads are 17lbs lighter than the cast iron ones. Aluminum heads and intake instead of cast iron makes a difference of 50lbs on the nose. (300)
"For all you Buick fans that can not get ahold of all of those 1964 Buick aluminum heads and was wondering the weight difference, I hope this helps."
Hope what helps? If you meant to include some actual weights here please do or I may delete this thread. There are some weights listed in other threads. |
I know of a couple of guys running cast 300/340 heads. Bigger valves. I was told the pair of heads adds just under 40 pounds to the engine. Only ever held the aluminum 300 heads.
