Buick 266 stroker
Since the TRW L2142CF pistons have long since been discontinued, are there any off the shelf pistons that can be machined to work or will I need to have custom made pistons?
I have a call in to Woody Cooper at the Wedge Shop, hoping he can educate me what my options are. |
Re: Buick 266 stroker
Per Phil Baker 266 recipe, he used TRW Ford 170 +30 pistons, I wonder what the difference is between the TRW and these Silvolites 170 +30?
[www.summitracing.com] In regards to Mark, he is too difficult to work with, and many find that to be true. It's like he doesn't want the business. |
Interesting that YOU found D&D difficult to work with. I found them knowledgeable and accommodating to share information and responsive to my questions. Just my opinion and experience. I would have no hesitation to interact with them(Mark) in the future.
I am not the only one that has found him difficult, customer's, symbiotic competitors and colleagues. I will leave it at that.
Woody seems to agree he thinks the Silvolite 170 30+ should work since same bore as 215/TRW 170. I will let the machinist assess and go from there. Edited 1 time(s). Last edit at 04/22/2022 06:14PM by oblvnnwtnjhn. |
Mark is indeed something of a "Character".
And that's all I'm sayin. Jim |
Or, use a 4.6L crank ? One piece Viton rear seal, ( counterbore seal area of 215 block), to fit. This crank will regrind to a
3.300" stroke. Why bother with a 215" block ? Many 4L and 4.6L 's available. Good Luck, Art. |
Spencer, The 215 liners are cast in and not replaceable without boring out and new liners pressed in. Too expensive. I would clean up the gouges and hone or bore as necessary. Nothing is going to hit that low. I put a 215 in a Jeep years ago with 300 heads milled .030, Offy dual port intake, 400 AFB carb,headers and Crower 50232 cam. That cam was a little too big and if doing again I'd use the 50230 and later Rover heads. I later built a 3.8 V6 and it had about the same power.
Right off the bat I would suggest you look for the Buick 300. With aluminum heads and intake it weighs right at 400 lbs so a very decent weight improvement. With iron heads and intake 450 lbs so still a little better. Bellhousing is the common BOP pattern so that should not be a problem at all and you may even turn a profit on your rare 215 bell. In the completely stock configuration it should give you everything you are looking for. That engine was justly famous for long life and durability.
@jim Nichols thanks for confirming my suspicions. I know they can be replaced but $$$. That's assuring to know I most likely can clean up and use as is.
@jim blackwood I already have $500 in the engine, traded some rare ARE Silverstone mags for it and $500 cash. I have some quality fair priced items for sale already, nothing is moving in my area and haven't seen but one 300 near me in the last year or so. So I'd rather use what I have, as nothing to lose even in stock trim as more benefits than my F head but about 75lbs lighter. |
Spencer, When you rebuild the 215 use studs on the mains as the caps move a bit. Rover has crossbolt mains. What intake will you use? I liked the Offy dual port on my Jeep. Performer is good too. Stock is okay.
I just heard back from Mark D&D and had a very pleasant, grounding call.
He said build it stock,.their flywheel,.their stage 1 cam, Egge pistons, with gaskets around $1650 ish which I think will be perfect. I appreciate him grounding me to reality and backing it up with facts and actual needs. |
@jim Nichols haven't decided yet. I think a good compromise in performance and MPG.
JET offers a reman two barrel carb that supposedly flows like a small four barrel. What would you suggest? |
Spencer, you are right the 215 will be better than what you have, but keep an eye open for the occasional 300. The torque is much higher and it'll be easier to drive slowly and all you need to change over is the engine and the bellhousing. Also that 215 stuff should sell here easily enough. Find someone building a GS clone and you might pick up a very nice 300 really cheap.
I used the 400 AFB that is no longer made. A lot of guys use the 500 Edelbrock and rejet it. There is also a 390 Holley that works well. If going offroad there is a spring loaded needle and seat and run the float bowls a little low. For two barrel I'd use an adapter and Holley two barrel. Egge has Olds 215 pistons that will raise the compression a little.
Edited 1 time(s). Last edit at 02/04/2023 05:07PM by mgb260. |
Just an FYI: Your Buick 300 crank can be fitted to any early Rover V8. The mains are virtually the same as the 215. Your 215 bellhousing also fits all Rover V8s (up to & including 2004).
Best o' luck on your 215 build. |
