donfaber Don Faber Terra Alta WV (111 posts) Registered: 10/31/2007 10:53PM Main British Car: 1979 MGB 3.9L Rover V8 |
Water neck for Rover v8
Just had distributor rebuilt for my rover v8 (Delco- Remy ) - can't set dizzy at recommended timing (18 deg BTDC) location because current water neck is too big. Is there a "standard" water neck for this manifold? are water necks basically one size fits all (at least to bolt onto the manifold)?
Re: Water neck for Rover v8
Can you pull the distributor and advance the shaft one tooth as you put it back in?
I believe so ....I did mount the dizzy right on TDC with #1 cylinder, so I'd prefer to maintain that position. Thanks for the suggestion!
You could gain space, slightly increase power, and improve reliability by converting to crank fired ignition.
You'd probably install a cam position sensor where the distributor goes, but it would be smaller diameter and shorter. Then you'd also add a tone wheel, probably either at the fan pulley or at the flywheel. Example photos here and here (scroll way down). I imagine that's also what Howard Fitzcharles did here, although there aren't nearly enough photos. |
Pics might help.
IF you just need a bit more range from your distributor, I would just clock it over one firing position. I had to that on my 68 Camaro back in the 80s when I switched over to HEI. Easy peasy. I have the Edelbrock intake that I have not yet used & I do not plan to switch to crank fired ignition to use it. Seems Jim Nichols mentioned many years ago there was difference between the Edelbrock & the Buick 215 manifold that needed a simple mod. I will have to dig it out. Found it. From Jim Nichols: Quote: Edited 1 time(s). Last edit at 03/18/2023 12:36PM by MGBV8. |
Plus, Use a pan head allen bolt for the front intake manifold for clearance for the distributor. Smaller distributor fits better than large coil on cap HEI. D&D has a nice swivel thermostat housing and some have drilled out the bolt holes of the Ford thermostat housing. I'd cut down the center divider under the carb base a 1/2" too.
Edited 2 time(s). Last edit at 03/18/2023 01:19PM by mgb260. |
Looking at Don’s photo, is the existing thermostat housing/water outlet not a swivel mount? Looks like D&D’s version.
1) I do currently have a swivel mount water neck. I've been looking for one like I saw in pic from Jim Nichols since last fall - any suggestions on where to find one would be appreciated. I'll reach out to D&D too. I'll also look at a Ford unit to modify - thanks for all the help!
2) Curtis - suggesting my engine area is a "bit congested" is kind. I' hope to do some work in there after I get timing straightened out. Don Faber |
