motek
George Smathers
Spokane, WA
(118 posts)
09/12/2009 02:45PM
1967 Morris Minor (48 hp @ crank!), 1971 TR6 302
Opinion on Carb hats/bonnets
Posted by: motek
Date: May 27, 2010 10:06PM
What do you guys think about using a carb hat? Like this one used by Jeb Blanchard. I have hood clearance issues and I'd like to avoid a hood scoop on my 302 TR6.
Thanks,
George
castlesid
Kevin Jackson
Sidcup UK
(361 posts)
11/18/2007 10:38AM
1975 MGB GT Rover V8 4.35L
Re: Opinion on Carb hats/bonnets
Posted by: castlesid
Date: May 29, 2010 03:28PM
George,
The problem is that if you do not have room say for a 14" x 2" with a drop base of 1 1/2" then you more than likely won't have room for a carb hat which in the centre will be approx 1 1/2" higher than the drop base filter.
If anyone makes a carb hat with a drop base and is no larger than 6" diameter then I would like to know as that would fit under my MGRV8 bonnet/hood otherwise it's a make it yourself situation.
Kevin
motek
George Smathers
Spokane, WA
(118 posts)
09/12/2009 02:45PM
Posted by: motek
Date: May 29, 2010 05:03PM
Thanks Kevin. I realize it will still stick up but I thought it might allow me to get away with a small diameter closed bubble - like on a TR4 - rather than a big open scoop.
Date: May 29, 2010 06:04PM
Webbers/DelOrtto's on a Offy etc. adapter to 4 bbl man. ? Side-ways better than no-ways, roverman.
britcars
Phil Ossinger
New Brunswick, Canada
(346 posts)
02/02/2009 07:58PM
1977 MGB Roadster, Rover 3.5 ADVENTURE BEFORE DEMENTIA!
Posted by: britcars
Date: May 29, 2010 09:44PM
Here's my solution in an MGB with a Rover 3.5. The aluminum can contains a Wix industrial air filter and draws cool air from in front of the radiator panel.
britcars
Phil Ossinger
(346 posts)
02/02/2009 07:58PM
Posted by: britcars
Date: May 29, 2010 09:46PM
A better view..................
Edited 1 time(s). Last edit at 05/29/2010 09:47PM by britcars.
(4636 posts)
Date: May 29, 2010 10:15PM
I've never had any particular problems with this carb hat / remote filter / cowl induction arrangement:
http://www.britishv8.org/MG/CurtisJacobson/CurtisJacobson-BE.jpg
Possibly a more streamlined path into the carb throat (and/or a bigger diameter for more plenum volume) would help it perform even better.
jblanchard@hcpg.net
Jeb Blanchard
Collierville, TN
(53 posts)
12/07/2007 01:01PM
1961 MGA Chevy 4.3 Vortec V-6
Posted by: jblanchard@hcpg.net
Date: May 29, 2010 11:02PM
George,
After investigating all options, the set up for my car was the only one that worked given hood clearances and working space. The design works just fine...
Good luck on your project!
Jeb Blanchard
eyeosteverino
Steve Kimball
Southwest NM
(30 posts)
03/02/2008 10:58AM
67 Sunbeam, 2.8 L V6 Ford,
Posted by: eyeosteverino
Date: June 05, 2010 03:29PM
It's hard to beat stock air cleaners, hood clearance wise. I modified a Yugo unit to fit the top of a Weber DGV and with some scrap tubes, made this cowl induction set-up. Since paper filters are kind of hard to find,I splurged on a K-N.
motek
George Smathers
Spokane, WA
(118 posts)
09/12/2009 02:45PM
Posted by: motek
Date: June 21, 2010 02:02PM
To avoid dropping my oil pan below the front cross member my engine is mounted a little high. I think I'll just bite the bullet and put in a hood scoop.
George
383 TR7
Jeffrey Frismanis
Minnesota
(6 posts)
06/14/2010 07:35AM
1976 TR7 convert. 383 sm blk Chev.
Posted by: 383 TR7
Date: June 23, 2010 08:12AM
Before you go cutting your hood check out Spectre Performance. They have all kinds of different low profile carb hats and plenums. The website has some expensive prices, but if you figure out what will fit try searching for it on Ebay.
Cut and paste this link
[spectreperformance.com]
383 TR7
Jeffrey Frismanis
Minnesota
(6 posts)
06/14/2010 07:35AM
Posted by: 383 TR7
Date: June 23, 2010 08:16AM
Here's what I'm planning on running from Spectre.
