cruiseman
Richard Woodley
Ameliasburg, Ontario, Canada
(32 posts)
01/21/2010 02:51PM
1972 MGB GT Rover 3.5
Metric oil filter base and pressure valve positioning
Posted by: cruiseman
Date: July 01, 2023 02:44PM
Had a problem recently with no oil pressure when I stopped for lunch. Flat bedded it home and checked for oil in the sump, (yes) tested the gauge, it works so felt it could be the oil pressure relief valve. Removed the cover and the spring but the valve would not come out so removed the Metric base from the front cover The valve did appear to have some crud on it and it would not slide in and out very easily. Did a light hone of the chamber and polished the valve before re-inserting it but realized the valve has a hole through it and am wondering how it should be re-inserted. Hole up and down or across or does it matter?
Richard Woodley
(4516 posts)
Re: Metric oil filter base and pressure valve positioning
Date: July 01, 2023 05:11PM
Hi Richard! Been quite awhile.
I do not recall mine having a hole. I think it was a solid cylinder. Mine's a 215 with the D&D metric swivel filter assembly.
I will go check my Rover 3.9.
(4516 posts)
Date: July 01, 2023 08:54PM
The one in my 3.9 looks just like this cylindrical one. The spring goes into it a good bit.
cruiseman
Richard Woodley
(32 posts)
01/21/2010 02:51PM
Date: July 02, 2023 05:19PM
Carl,
Attached is a picture of my valve with the hole.
(4516 posts)
Date: July 03, 2023 02:19PM
I've not seen one like that.
