383 TR7
Jeffrey Frismanis
Minnesota
(6 posts)
06/14/2010 07:35AM
1976 TR7 convert. 383 sm blk Chev.
TR7 Chev V8 headers?
Posted by: 383 TR7
Date: June 14, 2010 07:46AM
I recently purchased a 1976 TR7 that has a Chevrolet small block 383 stroker in it. Currently it has cast iron stock exhaust manifolds on it and I would like to upgrade to a set of full length headers.
I talked to a local speed shop and they told me they could build me a custom set but it was going to be around $1500.
Does anyone know if there is a set of headers from Hooker, Heddman, etc. that will either fit or fit with minimal tube modifications?
Thanks in advance for any help.
Here's a picture of the new toy.
DC Townsend
David Townsend
Vermont
(407 posts)
11/21/2007 12:22PM
Re: TR7 Chev V8 headers?
Posted by: DC Townsend
Date: June 14, 2010 09:30AM
Have you looked at any of the block hugger headers? Lots of choices including Hedman's "tight tubes" which appear to fit very close to the block. Not much of a Bow Tie guy but, from the picture you posted, it appears they might provide you with a solution.
WedgeWorks1
Mike Perkins
Ellicott City, Maryland
(460 posts)
07/06/2008 08:07AM
Posted by: WedgeWorks1
Date: June 14, 2010 09:31AM
You are going to have a lot of modification to a set of any headers you buy for the Chevy V8. To my knowledge no one make header for the Chevy small block in a TR7. You might want to buy a cheap set to get the header flange and portion of the tube and then buy a kit thta has all the bent tubing and collectors and make your own. It will be labor intensive but cheaper than paying for custom.
383 TR7
Jeffrey Frismanis
Minnesota
(6 posts)
06/14/2010 07:35AM
Posted by: 383 TR7
Date: June 14, 2010 11:26AM
Thanks for the suggestions.
I was hoping there was a set of headers that came close but just needed a couple tubes moved or something. I looked at Hooker and Hedman and they both have weld up kits.
Maybe I can mock something up and see if I can match it to a pair of existing headers.
The tight tubes and shorty style headers would probably work but will be my last resort.
I'll do some more checking, someone has to have done this before.
(6587 posts)
Date: June 14, 2010 12:09PM
Take a look at V8 Vega headers, they might be real close since it is also a small car. About the only real obstruction you have is the crossmember and most of it would be behind that anyway.
JB
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1166 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: June 14, 2010 06:43PM
There's a few Chevy small block "block hugger headers" on the market.
eg
[cgi.ebay.com]
Might be worth buying and then modifying to fit your application if necessary.
383 TR7
Jeffrey Frismanis
Minnesota
(6 posts)
06/14/2010 07:35AM
Posted by: 383 TR7
Date: June 15, 2010 07:38AM
After taking another look last night block huggers won't work. Since they are a center dump it would land right on top of my motor cross member.
I found that headers from a late 80's, early 90's Suburban look like they may work. I also found that Schoenfeld makes a forward swept sprint header that may work also.
I'll update with any progress I make.
bplus
Tracy Moore
Jacksonville, Fl
(40 posts)
11/24/2008 06:36PM
71' MGB GT 350 Chevrolet
Posted by: bplus
Date: June 16, 2010 07:03PM
Take a look at sandersonheaders.com They make several different types of
headers for the small block chevrolet, some are rear dump too, might help in
your installation.
383 TR7
Jeffrey Frismanis
Minnesota
(6 posts)
06/14/2010 07:35AM
Posted by: 383 TR7
Date: June 18, 2010 07:37AM
Sanderson has some headers that look like they would work. However I've read some pretty bad reviews of their products so I'm skeptical. I'm really starting to lean towards just a nice pair of Chevy ram horn cast iron manifolds.
Dan B
Dan Blackwood
South Charleston, WV
(1009 posts)
11/06/2007 01:55PM
Posted by: Dan B
Date: June 18, 2010 10:55AM
How did a 76 TR7 get to be a convertible?
(2633 posts)
Date: June 18, 2010 10:45PM
Speedway Motors has 2 1/2"dump Ram's horn manifolds. Smooth castings, flow as well as block huggers,reasonable price.
