mabie1978
Michelle Pierce
Elyria, OH
(111 posts)
08/25/2008 07:47PM
1978 MGB 3.5 Rover V8
Source for the small breather on the Rover valve cover
Posted by: mabie1978
Date: June 30, 2010 09:42PM
Does anyone know if they still sell those little breathers that are on the one side of the Rover valve cover? Mine engine is a 1988 and I am planning to use a PCV valve along with using the original style of the little breather (I guess you can call it). To me it is a tiny little metal straw with a circular disc on top. Any ideas? I am getting closer, which is why the questions are getting stranger :).
(6587 posts)
Re: Source for the small breather on the Rover valve cover
Date: July 01, 2010 12:41AM
Michelle, review the article on PCV systems in the last issue of the newsletter, you really can't mix-n-match parts from the American system (PCV valve) with parts from the British system (orifice breather), it has to be one or the other to work properly.
You can cut off the disc and use the stem, slip a short piece of vinyl tube over it to increase the diameter and then fit a common parts store small filter element.
The OEM parts are available from British vendors at a somewhat higher cost.
JB
Edited 1 time(s). Last edit at 07/01/2010 12:42AM by BlownMGB-V8.
mabie1978
Michelle Pierce
Elyria, OH
(111 posts)
08/25/2008 07:47PM
Date: July 01, 2010 11:52AM
I thought of doing that but wasn't sure if that would allow too much oil movement. If that is the best way I don't have a problem doing that. Did Rover not use a PCV in the late 80's in the other opening?
(6587 posts)
Date: July 02, 2010 01:25AM
Not that I'm aware of.
[www.britishv8.org]
JB
