62Healeyhacker
Jerry Jackman
(19 posts)
04/11/2009 10:58PM
reworking the clutch slave cylinder setup
Posted by: 62Healeyhacker
Date: August 13, 2010 11:49AM
The mount I made for the slave cylinder on my Healey/Buick 215" flexes and is not perfectly aligned. It there a way to keep the slave setup or am I going to be forced to get a hydraulic throwout bearing. The frame rails on the AH are only 17" apart so the space to work in is tight. Does anyone make a mount which bolts to the bellhousing? I have seen these on SB Ford engines.
If I need to resort to a hydraulic TO bearing which is reliable for the least amount of money? I've noticed an extreme variation in prices.
Any ideas?
Re: reworking the clutch slave cylinder setup
Date: August 13, 2010 01:03PM
Sometimes home-made parts don't work out and you get to go back to the drawing board... but the cost of making a second (differently designed) bracket is probably less than buying a new slave cylinder.
Just for reference, this is what my home-made bracket looks like:
http://www.britishv8.org/MG/CurtisJacobson/CurtisJacobson-K.jpg
(Credit where credit is due... this bracket was actually designed and made for my car by one of my buddies, Rob Henson. So it's home-made, but not by me. The strut that runs forward to an oil pan bolt was obviously an afterthought; added to stiffen things up. It's simply half inch box tubing with washers at both ends... very "minimal" but it does the job.)
Edited 1 time(s). Last edit at 08/13/2010 01:10PM by Moderator.
7sand8s
Dennis Miller
(36 posts)
09/21/2008 10:47PM
Posted by: 7sand8s
Date: August 13, 2010 02:18PM
Curtis
Could you give us more info?
Brand and Part Number of slave cylinder.
Thanks
PS A great design!
Date: August 13, 2010 03:53PM
It's a Girling cylinder. I've noticed that similar cylinders were used on many, many vintage British racecars. For example:
http://www.britishracecar.com/HowardFreeman-Merlyn-11/HowardFreeman-Merlyn-11-BC.jpg
These are available in several sizes/configurations. Start here... [www.pegasusautoracing.com]
Now, I'm not sure I'd use a Girling slave cylinder if I didn't already have one. Some of the new pull-type cylinders are really nifty. Something to keep in mind: I shortened the stock Buick throw-out fork to suit this installation, so there's less leverage and consequently higher pedal effort than the original Buick system would've had. Fitting a diaphragm-type pressure plate (in lieu of Buick's old three-finger plate) got pedal effort back down.
62Healeyhacker
Jerry Jackman
(19 posts)
04/11/2009 10:58PM
Date: August 14, 2010 01:32AM
Nice looking bracket. I'm sure the angled support to the pan bolt is needed because a lot of pressure is put against the bracket and the single bolt on the side of the block isn't adequate.
Many thanks for the prompt responses.
Date: August 14, 2010 07:36PM
Jerry, there are also, "push/pull" slave cylinders available. Their sold by companies like Stock Car Products, etc. Sometimes "pulling" the arm is easier. Good Luck, roverman.
