Merlin Magic ?
Is it possible ? Only 6 months ? I ordered Real Steel's heads on 3/12/2010 an..an NOW there ready !! .Let the "fun" begin. roverman.
Edited 1 time(s). Last edit at 09/14/2010 06:38PM by roverman. |
Re: Merlin Magic ?
Well it may well be magic if you have ordered them in the future. Over here 3/12/2010 would be 3rd December 2010!
Re: Merlin Magic ?
David, Unfortunate indeed. So Real Steel is still not convinced, market demand is not strong enough, for higher production rates ? It isn't like Wildcat or TA are "real" competitors. I suppose, I should have guessed, If I bought "heavy" in Stage II Buick V6 parts, my "Merlins" would magically appear ?
Edited 1 time(s). Last edit at 09/08/2010 01:43PM by roverman. |
Re: Merlin Magic ?/ compo?
Greg and clan, We have flow #'s for 300's. Thanks to "Jukka", of this forum ,for Merlin #s. roverman.
Edited 1 time(s). Last edit at 09/29/2010 09:44PM by roverman. |
Re: Merlin Magic ?
I must admit when I saw the title of the thread I assumed you we going to use a supercharged Rolls Royce V12 out of a Spitfire.
Re: Merlin Magic ?
David, like I've never been accused-here, of being "out-there", lol. Good news is , I can't count past eight. I might have titled "F-85" heads, but since they have as much in common as a Rolls V (8+4) ??
Edited 1 time(s). Last edit at 09/09/2010 11:20AM by roverman. |
Re: Merlin Magic, priority oiling ?
Since I'm "planning" on receiving heads,(maybe they'll ship this week), might as well start on a Rover race motor. Flanged liners, of-course, block filler? Dry sump with priority oiling through oversize main cross bolts(hollow).Girdle. Belt drive on cam ? Mech roller cam/rockers. Oil through ends of rocker shafts ? Ideas ? roverman.
Edited 1 time(s). Last edit at 09/15/2010 04:26PM by roverman. |
Re: Merlin Magic ? or moderate moment ?
Their Shipping ! Yeah ! Why am I so excited about a conservative replacement head ? Because their "available" and you don't have to sell an "organ", to buy a set. I try to look at stuff, for it's potential, ie. "dreamer" but "we" shall probe their REAL steel-value. Hey TA, too bad your missin the boat,(literally). Stay tuned clan, were gonna "roll with the flow", roverman.
Re: Merlin Magic ? flow bench on wk-end ?
Well Maybe......not.
Edited 1 time(s). Last edit at 09/29/2010 09:45PM by roverman. |
Re: Merlin Magic ?/maybe not
"IT came from across the pond". You build a "strong/physically", after-market head, because it will "need" a blower. Kinda explains the 6 bolt per bore, "potential". You design the chamber for a 3.5" bore, and THEN find out the head doesn't WORK on a 3.5 L ! Now your 3.56" wide chamber is perched on top of a 3.7-3.76"+ bore. Intake"peaks at .433" lift. Do we follow here? In theory only, one might want the head to do well, so "others" might want to buy ?, but since your only willing to build,insufficient numbers, at a time, why bother ? "OZ", on the other hand, believes strong enough in the Rover, to pay "TA" of America to develop, a "serious" head.What is wrong with this picture ? 2 cents+, roverman.
Edited 1 time(s). Last edit at 09/29/2010 09:51PM by roverman. |
phongshader Justin Brown Ca (63 posts) Registered: 02/19/2010 04:03PM Main British Car: Locost Lotus 7 2.3 Duratec |
Re: Merlin Magic ?
Hi Art,
What was the upshot of these heads? I have a set of 300 heads that I'm going back and forth on wether I should throw big valves in and port them or go with a set of Merlin heads. The cost is about the same between the 2 options. Thanks, Justin |
Re: Merlin Magic ?
Justin, I would follow the "TA heads" threads. If your considering spending approx $1.5k on your 300 heads, you could get TA's "bare", for same amount. I suspect the TA heads will have much better resale value and hp. potential.This depends also on what level of build ? The TA heads will add approx. 18 lbs. of weight over 300 heads. Deal breaker ? As you might guess, much stronger, and they'll take oem buick rockers/shafts OR sbc. shaft mounted aftermarket rocker assembies. Cheers, roverman.
Re: Merlin Magic , revisited
Anybody using these/ vintage racing ?To refresh, Merlin heads, ported by Todd McKenzie, Intake flow , 28" with 1.770" valve lifted .100"=60 cfm., .200=121.8, .300 =180, .400=210, .500=216.5 and .600=219.2. As I interpret SCCA rules, this "should" be a legal replacement head,(standard valve centerlines @ 1.660"). These haeds shine at low and mid-lifts. Onward, roverman.
Edited 1 time(s). Last edit at 03/08/2013 02:14PM by roverman. |
Re: Merlin Magic ?
Hi Art,
Thanks for the reply, I'm just trying to figure out which is more cost effective. I've gotten quotes between $1.5-2k for larger valves and bowl porting on the 300 heads and around $2k for the merlin heads shipped. Are the bare TA heads buildable for $2k? The question really is what would flow better in the $1.5-2k price range, stock unported Merlin heads or worked 300 heads? Thanks, Justin |
Re: Merlin Magic ?
What do the complete TAheads cost?
Re: Merlin Magic ?
I think they're round about $2795...too rich for me
Re: Merlin Magic ? TA value ?
Justin, $2k for bowl ported, larger valved 300 head work, seems like a lesser value, IMHO. TA heads take sbc parts= save $'s. I have all three brand heads, and would choose TA for their standard flow and potential, with porting. Onward, roverman.
