kenzmyth
Ken Smith
San Rafael, CA
(55 posts)
12/09/2008 10:50AM
1966 MGB Roadster 67-76 Rover 3500S 3.5 Liter Hi Comp #4300000A seri
Fuel Pump Recommendations for a Rover 3.5 L
Posted by: kenzmyth
Date: October 10, 2010 01:13PM
I am currently running a JEGS electric fuel pump on my car and it functions fine. However, it is a very loud
pump that runs constantly. Any suggestions for a quieter pump? I was tempted to just mount the electronic
SU I had on the car for the 1800 engine, but wasn't sure it would supply enough pressure for the Edelbrock
#1404 4BBL carburetor requiring 4-5psi at WOT. I have read through a number of How It Was Done articles, but none address the noise factors. Thanks.
WedgeWorks1
Mike Perkins
Ellicott City, Maryland
(460 posts)
07/06/2008 08:07AM
Re: Fuel Pump Recommendations for a Rover 3.5 L
Posted by: WedgeWorks1
Date: October 10, 2010 03:15PM
The TR8 has an internal gas tank fuel pump that runs about 2.5 psi for the Zenith Strombergs and when we convert to a 4 barrel we still use the stock pump and never had any issues with fuel pressure.
tr8todd
Todd Kishbach
(390 posts)
12/04/2009 07:42AM
Posted by: tr8todd
Date: October 11, 2010 09:01AM
VWs and other Euro cars use little rubber isolator bushings that are ideal for mounting electric fuel pumps. They look like a barbell with bolts and nuts sticking out both ends. They do wonders for cutting down on the noise.
kenzmyth
Ken Smith
San Rafael, CA
(55 posts)
12/09/2008 10:50AM
Posted by: kenzmyth
Date: October 11, 2010 10:42AM
I discovered that the JEGs pump is a diaphragm style and even with the rubber isolators it is still quite noisy.
I am going to purchase a Carter or Edelbrock rotary vane pump which, according to the spec sheets should be quieter by a large factor.
Thanks.
(1365 posts)
Date: October 12, 2010 12:57PM
Hi Ken,
If the diaphram pump is too noisy then the Carter/Edelbrock pumps are going to be a dissapointment.
They are "loud".
They advertise 4 to 14 db quieter which means they went from a jumbo jet on take off down to a freight train at full power.
Like Mike, I'm a big fan of in tank pumps. They are silent, powerfull and durable.
Every OEM that I know of uses this type of pump, and for good reason.
There is another thread on the forum that you might want to check out. It goes into the fuel pump issue with a few different viewpoints.
What ever you choose, make sure to use an inertia switch to keep everything safe.
mabie1978
Michelle Pierce
Elyria, OH
(111 posts)
08/25/2008 07:47PM
1978 MGB 3.5 Rover V8
Posted by: mabie1978
Date: October 13, 2010 03:26PM
I just put a new SU type in mine, after the old one kicked the bucket as soon as the v8 started running.
roverart
Vincent von Frese
Kansas City, Missouri U.S.A.
(3 posts)
08/08/2010 12:10PM
1980 Rover 3500 V8
Posted by: roverart
Date: October 23, 2010 10:04PM
I have a 1980 Rover 3500 V8 with an external Bosch fuel pump. This pump went flat. The numbers on it are 0 580 463 013 and a 12 V 341 and 041. The ends are male for pos and neg. What can I order to match this fuel pump and or is it the right one?
In other words; does anyone know if TR8 pump will work or any other type of fuel pump? I have not seen these exact numbers on the internet search.
Any help will be appreciated. Thanks in advance.
(1365 posts)
Date: October 25, 2010 01:42PM
Hi Vincent,
The Bosch #s that you are looking for are 69469 or 69536 either will work. The pumps are the same as several 75-91 volkswagen models, porsche 914s and 79-91 jags.
Any parts store should be able to dig up something comparable if not the same.
If you are looking for a used one concentrate on jaguar as they are mounted in the trunk and generally in better shape.
Hope thats helpful.
Dave
David Gable
Jax
(112 posts)
10/23/2007 05:40AM
Posted by: Dave
Date: October 27, 2010 05:21PM
1984 Accord carb pump.
(1365 posts)
Date: October 27, 2010 06:15PM
Hi Dave,
I didn't specifically ask him, but Vincents car ought to be a fuel injected model.
