Infinity motor
Re: Infinity motor
The cost of this one is prohibitive,800HP Indy500 motor. The base motor 300-400HP can be found in junkyards.Probably$1500+ range.
Re: Infinity motor
You can get them in anything with a 45 in the name. I.e. M45, Q45, etc. Nissan uses the motor also, and the truck version is a 5.6L, though heavier.
The VQ45 is a nice motor, and the bore spacing on the heads is remarkably close to an SBC, making a DOHC SBC possible, though not easy. Don't forget the Toyota 1UZ and It's successors, that should always be an option when the VK45 is considered. |
