3.5 Rover venting and oiling
Racers,
Curtis may be glad to know that a first attempt to "fix" the venting and oiling problem with the RV8 GT2 car, incorporates his suggestion for fixing the problem. That is, a heavy new hose connecting the fuel pump port to the vent-to-catch tank hose from the left side valve cover. Bill Young crafted a new plate and coupling to the fuel pump port and a new coupling to the valve cover port to the catch tank. Photos to follow. keep them on the track phillip g |
Re: 3.5 Rover venting and oiling
Guys here with the larger 4.6 and 4.4 engines use a vacuum pump and have no issues with crank case pressure or oiling.
Chromov Andrew Studentsov Russia, Moscow area (11 posts) Registered: 08/03/2011 01:19AM Main British Car: GAZ 2410, 1988 year ZMZ 402.10, 2,45 litres |
So, where are the photos?
Is it possible to install oilpump of 4.4 or 4.6 into 4.0 engine? It has greater efficiency, I guess P.S.: Sorry for my english, if i did mistakes - not my mother tongue |
The 4.0 with 4 bolt mains has the same oil pump as the 4.6 also same timing cover.
Not a problem. The 4.0 and 4.6 differ in the crank, pistons & connecting rods. The heads, block, timing chain, timing cover, etc are all the same.
Here is what I have for venting/catches
H Edited 1 time(s). Last edit at 08/12/2011 08:38AM by WedgeWorks1. |
Sorry for off-top, but are there some tables with measurements of cranks, pistons, etc. of Rover V8, and other differs of these engines?
