can you i.d. this axle housing?
I don't recognize this axle housing... and wondered if any of you guys can I.D. it:
It's installed on a 1950ish Jag XK-120 Special, but I don't believe it's original to the car. |
Re: can you i.d. this axle housing?
Look up Salibsbury 2Ha housing. They were found in early jags and had perfromance parts offered.
Thank you! Exactly what I needed, and your tip (2Ha) gave me the right Google search term to find a bunch more.
The upgrade is a Salisbury 4Ha, 7Ha and even a 8Ha? These are all English Built Dana rear axles. I know the Salisbury 4Ha is a Dana 44. The others I dont know but the 2Ha could be the 20 or 35 Dana? Good Luck!
