Rover v8 build: 4.0 block, 4.0 pistons, 4.6 crank and rods, 3.9 heads
Hi All,
I am contemplating the following Rover V8 build: 4.0 block, 4.0 pistons, 4.6 crank, 4.6 rods and 3.9 heads. I was told that 4.0 pistons combined with 4.6 crank and rods will yield a compression ratio somewhere in the neighborhood of 10.9:1, which IMHO is a bit high. I am wondering if I use the 3.9 heads (37 cc) instead of 29 cc 4.0/4.6 heads, what will be the compression ratio in my build? |
Re: Rover v8 build: 4.0 block, 4.0 pistons, 4.6 crank and rods, 3.9 heads
I did the math based on [en.wikipedia.org]
With stock 4.6 pistons,rod and crank, assuming bore=94 mm stroke = 82 mm Compression ratio Cr=9.35 We get Chamber volume Vc = 68cc According to clever and resourceful folks on discoweb, with 4.0 pistons, 4.6 rod and crank, the Cr turns out to be10.9, which in turn means that the chamber volume turns out to be Vc ~ 57.27 If we slap a 3.9 head instead of 4.0/4.6 on that puppy we increase the Vc to approximately 65.27 Which yields us a compression ratio of approximately 9.71 While 9.71 != 9.35 it should be workable with premium gas only, especially given the fact that GEMS has knock sensors and knows (how to/when to) retard ignition timing and enrich the mixture. |
You guys are amazing,.
Are you all former GM & Ford engineers ? Where'd you come from ? keep them on the track, phillip g |
