RobertE
Robert Edgeworth
(77 posts)
02/19/2008 08:27AM
14CUX O2 Sensor
Posted by: RobertE
Date: November 16, 2011 04:05PM
Anyone have any suggestions on where to find (1)O2 sensor? One of my friends managed to ruin the driver side o2 sensor unfortunately - I've already tried junkyards and I'd rather avoid the $140 other places want
Someone mentioned they thought I could use any 3 wire sensor but I've never heard this.
RobertE
Robert Edgeworth
(77 posts)
02/19/2008 08:27AM
Re: 14CUX O2 Sensor
Posted by: RobertE
Date: November 21, 2011 11:25AM
I did some research on the subject(british v8/land rover owners forum) and found a few different nissan o2 sensors that are suppose to be exactly the same(difference in price and plug).
Checked a few local parts stores and only one of the nissan sensors is stocked. Price $70(couldn't afford to drop the $400 LR wanted).. Only difference I can see is the plug and that the sensor sits more towards the center the center of the downpipe. Will this make an significant difference if I use it while having a stock o2 sensor on the opposite bank? The difference is a few centimeters at most - so I'm thinking its negligible.
Also whats the best way to actually tell if its working? i don't have the diagnostic box that some people run with the 14CUX - Can I just drive around for a bit and then pull the plug to check if its running too rich?
I'm going to change the plug and install it over my thanksgiving break - I'll let yall know how it goes.
Re: 14CUX O2 Sensor
Date: November 21, 2011 02:21PM
Robert, check with the guys over at Megasquirt and perhaps Innovative Motorsports. That's very expensive even for a wideband O2 and if it's a narrow band it's flat out highway robbery. $20 would be more appropriate for a narrow band.
JB
(2465 posts)
Re: 14CUX O2 Sensor
Date: November 21, 2011 07:44PM
Robert, Chris Gill on MGExperience went through this. With the Rover ECU you have to use the Rover (or Nissan similar) to work .
cgill
Chris Gill
Salmon Arm, British Columbia
(129 posts)
08/13/2009 12:06AM
1979 MGB roadster Buick 300 stroker with EFI
Re: 14CUX O2 Sensor
Posted by: cgill
Date: November 23, 2011 01:18PM
Jim's right. I ended up finding a pair of used oxygen sensors and they seem to be working.
Take a look at this page about half way down. They have some ideas that might work for sensors
[www.rangerovers.net]
Here's another pertinent article about oxygen sensors...
[www.jpurnell.com]
MGB-FV8
Jacques Mathieu
Alexandria, VA
(299 posts)
09/11/2009 08:55PM
Re: 14CUX O2 Sensor
Posted by: MGB-FV8
Date: November 27, 2011 09:51PM
Robert, oxygen sensor brands seem to have toggling voltage differences, I don't know why. Some vehicles don't seem to agree with a universal after-market brand; although they test good, it will not meet the vehicle's ECU requirement. Always check the OE manual for the proper 02 sensor specifications. Here's an excellent link on 02 sensors. [www.autodiagnosticsandpublishing.com]
When using an after-market brand on GM vehicles, I always had better luck with a Delco or Nippondenso. I know some guys (technicians) that will cut the plug off the end of a sensor that came from another brand vehicle and successfully rewire it for their vehicle; of course, they have perfect understanding of their work and own the proper test equipment.
Good luck,
Jacques
