rkas3882
randy kassed
(84 posts)
05/30/2010 09:14AM
1973 mgb gt rover 3.5
fuel connection rover efi
Posted by: rkas3882
Date: November 27, 2011 10:07PM
Hey guys, the rover 3.9 efi system has an odd thread on fuel fitting for the fuel line, what have you guys done to connect the fuel line? is there some type of threaded nipple i can get so i can just use some push on fuel line?
Randy
en
ian jenkins
Mississauga Ont canada
(67 posts)
12/27/2010 11:06AM
77 tr7
Re: fuel connection rover efi
Posted by: en
Date: November 28, 2011 06:28AM
I'm not sure of the thread but i cut the nut off and use high pressure EFI rated hose.
The tube under the nut is larger od than the rest of the tube(thats why the nut won't slide off)
avbates
Tony Bates
San Jose California
(25 posts)
03/22/2008 12:16PM
74 MGB roadster 4.2 litre Rover
Posted by: avbates
Date: November 30, 2011 09:53AM
From receollection I believe the thread is something like 12 mm x 1 mm. I searched high and low looking for a solution with ho success, everything seemed to 1.5 mm. Ending up like Ian and carefully cut off the nut, leaving the nipple intact and used a normal clamp
Regards
Tony Bates
